on 05-12-2022 12:23
Hi There,
My Hub 3 has a White/yellow stable light (not flashing).
But my wifi is not working. I reset and then it worked for a short while and then did not work again, please help ?
I tightened loose cables and reset the hub too.
Neill
on 05-12-2022 12:39
Only other suggestion is to do a pinhole reset and hold down for 45 seconds. It might be worth check the service checker you may be having intermitted issue which can effect your wifi the usually last for around 24 hrs here is a link for the service checker https://www.virginmedia.com/help/service-status
on 05-12-2022 14:44
