on 04-11-2021 14:04
I recently purchased a Samsung Qled TV for my living room and would like to connect my super hub 2 modem to it, which is based in a different room. The modem is about 15 metres away. Can you advise which router works well with a super hub 2 and what speed category ethernet/patch cable is best, i.e 5e, 6, 7 etc? FYI. My connection is speed is currently 200mps.
on 04-11-2021 14:10
on 04-11-2021 14:19
on 04-11-2021 14:29
on 06-11-2021 16:59
Hi @Cubase27 thanks for posting and welcome to our community.
Have you resolved your hub to tv connection issue?
Lee_R
on 06-11-2021 17:13
Hi Lee,
Thanks for your message.
Yes, I now know what type of Ethernet cable to buy, but since I’ve only received one router recommendation therefore not sure which to buy as there are so many on the market and Ive read that some don’t work well with superhub 2.
06-11-2021 17:30 - edited 06-11-2021 17:34
See this long ramble I have posted previously - I use a SH2 in modem mode and all is fine.
________________________________________
The cognoscenti will always say (correctly) that the best thing to to do is connect Wireless Access Points directly to the Hub or your own better router by ethernet cables. However some would say a good Mesh will be the best/simplest/most flexible for most average users who dont want to run ethernet cables. . A Tri-band Mesh system is better for the "backhaul" and for users on high speed packages and umpteen simultaneous connections. Wifi6 is future proofing too.
Another option is to extend the ethernet connections (and wifi) via powerline adaptors - they work well for lots of people - including for my "gaming son" in his bedroom and they can be "cheap and cheerful".
It depends on your requirements for... better routing features, your house layout, size, construction materials, your tech abilities, and of course, budget, ~£50-80 will get a decent introductory wireless router but 'may' not alone solve the wifi in your house, but spending ~£500 will get the “Rolls Royce” solution of a high-end Wifi6 Router & WAP's or a top end Tri-band Mesh system with WiFi6 (may cost a bit more). You'll probably want something suitable - somewhere within that range - I reckon ~£100-150 is around the “sweet spot” for most standard users, and where you would probably need to start for a standard 2/3-story house if it has brick walls. Less for a one-bedroom modern build flat, more for a stone built 8 bedroom mansion and more bells and whistles
Good options for Access points/Wifi routers/Mesh systems come from Ubiquiti, Asus, TP-Link Deco's M4/M5, Linksys Velop's, Netgear Orbi's (and others) – I would stick with these companies whose business this is - rather than “newcomer” and data-driven” companies like Google, Amazon, etc. Also be sure the router or Mesh specifically says that it is suitable for a cable connection and they have 1GB ethernet ports - some of the cheaper ones only have 100Mbps ports. WiFi6 is also future proofing for faster connections.
Recently, just as an example... three of my friends who all live in brick built 3/4 bed semis, just got TP-Link Deco M5 3-packs (~£150) and all said it is - “absolutely brilliant with excellent wifi speeds in all rooms, the attic and the garden, and the App is a doddle to use”. The first Mesh unit becomes the new router - you need to check whether the one you look at has all the "features” you need. Ethernet ports are usually limited to 1 or 2/unit , so you “may” need to add in an unmanaged GB port switch (<£20) in there as well. My mates also get "full speeds" from the ethernet ports on the Deco's in the remote locations. Finally if you get a 2/3-pack of any Mesh system, which doesn’t cover dead spots everywhere, you can just add in extra unit(s). The cheaper Deco M4 2 or 3-pack is also a good choice for ~£100.
Take a look at what fits your needs, tech ability, house layout and budget. Use sites like Techradar & Techadvisor for reviews of "Best Routers" or "Best Mesh". Post again if you want personal recommendations from others on your short list
on 06-11-2021 17:34
Priceless information, thanks very much John!
on 06-11-2021 17:38
on 06-11-2021 18:55
Many thanks, John.
