on 16-01-2023 19:22
I'm not sure what is up with my connection, but I'm at the point now I have ot reboot the hub (modem mode) every 24-36 hours. After a certain period of uptime, the connection just becomes unstable.
For the most part, a reboot of the hub clears this. I've also recently pin reset the hub and as seen by the top graph, the issue is still there, but worse?
My downstream pre-post errors are all 0, however at the bottom, my correcteds are in the billions?
159 | 96 | 4K | 1880 | QAM4096 | 759 |
159 | Locked | 39 | 3.8 | 1667568958 | 0 |
All my downstream channels are pretty clean (I think?)
25 | 331000000 | 5.099998 | 38.605377 | QAM256 | 25 |
18 | 275000000 | 5.199997 | 38.983261 | QAM256 | 18 |
19 | 283000000 | 5.000000 | 38.983261 | QAM256 | 19 |
20 | 291000000 | 4.599998 | 38.983261 | QAM256 | 20 |
21 | 299000000 | 4.400002 | 38.605377 | QAM256 | 21 |
22 | 307000000 | 4.300003 | 38.605377 | QAM256 | 22 |
23 | 315000000 | 4.599998 | 38.983261 | QAM256 | 23 |
24 | 323000000 | 5.099998 | 38.605377 | QAM256 | 24 |
So, I'm at a loss as to why this is happening, and when I timed it a couple of weeks ago, the micro disconnects were exactly 30 minutes apart. What's weird, I still receive data, but my upstream stops during these DC spikes. I can hear other people on voice calls, but they stop hearing me, this is how I know if I'm in a bit of a DC spike.
on 16-01-2023 19:30
Logs below:
26 | 339000000 | 4.900002 | 38.605377 | QAM256 | 26 |
27 | 347000000 | 4.699997 | 38.605377 | QAM256 | 27 |
28 | 355000000 | 4.599998 | 38.605377 | QAM256 | 28 |
29 | 363000000 | 4.500000 | 38.605377 | QAM256 | 29 |
30 | 371000000 | 4.699997 | 38.605377 | QAM256 | 30 |
31 | 379000000 | 4.699997 | 38.983261 | QAM256 | 31 |
32 | 387000000 | 4.599998 | 38.983261 | QAM256 | 32 |
33 | 395000000 | 4.599998 | 38.983261 | QAM256 | 33 |
34 | 403000000 | 4.699997 | 38.605377 | QAM256 | 34 |
35 | 411000000 | 5.000000 | 38.983261 | QAM256 | 35 |
36 | 419000000 | 5.300003 | 38.605377 | QAM256 | 36 |
37 | 427000000 | 5.400002 | 38.605377 | QAM256 | 37 |
38 | 435000000 | 5.599998 | 38.605377 | QAM256 | 38 |
39 | 443000000 | 5.599998 | 38.983261 | QAM256 | 39 |
40 | 451000000 | 5.800003 | 38.605377 | QAM256 | 40 |
41 | 459000000 | 5.300003 | 38.983261 | QAM256 | 41 |
42 | 467000000 | 5.300003 | 38.605377 | QAM256 | 42 |
43 | 475000000 | 5.099998 | 38.983261 | QAM256 | 43 |
44 | 483000000 | 5.400002 | 38.983261 | QAM256 | 44 |
45 | 491000000 | 5.300003 | 38.983261 | QAM256 | 45 |
46 | 499000000 | 5.400002 | 38.605377 | QAM256 | 46 |
47 | 507000000 | 5.500000 | 38.983261 | QAM256 | 47 |
48 | 515000000 | 5.400002 | 38.983261 | QAM256 | 48 |
25 | Locked | 38.605377 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 38.605377 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.605377 | 0 | 0 |
26 | Locked | 38.605377 | 0 | 0 |
27 | Locked | 38.605377 | 0 | 0 |
28 | Locked | 38.605377 | 0 | 0 |
29 | Locked | 38.605377 | 0 | 0 |
30 | Locked | 38.605377 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
32 | Locked | 38.983261 | 0 | 0 |
33 | Locked | 38.983261 | 0 | 0 |
34 | Locked | 38.605377 | 0 | 0 |
35 | Locked | 38.983261 | 0 | 0 |
36 | Locked | 38.605377 | 0 | 0 |
37 | Locked | 38.605377 | 0 | 0 |
38 | Locked | 38.605377 | 0 | 0 |
39 | Locked | 38.983261 | 0 | 0 |
40 | Locked | 38.605377 | 0 | 0 |
41 | Locked | 38.983261 | 0 | 0 |
42 | Locked | 38.605377 | 0 | 0 |
43 | Locked | 38.983261 | 0 | 0 |
44 | Locked | 38.983261 | 0 | 0 |
45 | Locked | 38.983261 | 0 | 0 |
46 | Locked | 38.605377 | 0 | 0 |
47 | Locked | 38.983261 | 0 | 0 |
48 | Locked | 38.983261 | 0 | 0 |
on 16-01-2023 19:30
1 | 36600000 | 46.270599 | 5120 KSym/sec | 64QAM | 3 |
2 | 23600000 | 45.270599 | 5120 KSym/sec | 32QAM | 5 |
3 | 30100000 | 45.770599 | 5120 KSym/sec | 64QAM | 4 |
4 | 43100000 | 46.270599 | 5120 KSym/sec | 64QAM | 2 |
5 | 49600000 | 46.270599 | 5120 KSym/sec | 64QAM | 1 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_STDMA | 0 | 0 | 2 | 0 |
6 | 10.0 | 50.5 | 2K | QAM8 |
6 | OFDMA | 200 | 53.9 | 0 | 0 |
Network log is blank (this seems a common problem when I'm experiencing these "30 minute disconnects")
16-01-2023 19:43 - edited 16-01-2023 19:44
Very similar topic here with the cyclical dropouts every 30 min
on 16-01-2023 19:55
Look at my post if you can find it. I HAD Exactly the same probleM.
Things I noriced on mine:
When in Hub4 was in the default settings so all smart wifi enabled and so on I would have drops every half hour. Separating the bands moved drops to every 1h or so. In the end had my Hub4 replaced to Hub 5 and so far touch the would no drops.
on 19-01-2023 08:48
Hi Nex 👋 welcome back to the community, thank you for posting!
Sorry to hear about these issues with your drop outs. Having had a quick look on our systems there don't appear to be any issues at the exchange that cause concern.
We do just have to complete a few different checks as part of our processes to offer further support. Including ruling out any 3rd party equipment you are using (Eg an alternative router.) With this in mind you have mentioned that you are running your system in modem mode at the moment - is there any chance you would be able to revert to router mode so we are able to collect some data from the VM hub and offer further support with this?
Please do reply and let us know if this is possible, even just for a couple of days so we can collect some data. (You will also be able to see it yourself if interested via 👉 samknows.com/realspeed).
Thank you! All the best.
19-01-2023 09:03 - edited 19-01-2023 09:04
@Molly_T wrote:is there any chance you would be able to revert to router mode so we are able to collect some data from the VM hub and offer further support with this?
I doubt the data will be useful then what modem mode shows😞
on 22-02-2023 17:15
I totally forgot about this thread!
Realspeed test:
I'm connected to the hub now directly via cable to my desktop.
Setting up a new TBB graph to monitor too. Again, this only seems to start being an issue after ~24h uptime.
Had an outage last night for 15 minutes or so, while ringing CS up, and I got the "useful" answer that my hub needed replacing, which, it clearly doesn't as I'm connected to it right now. I was trying to indicate that something in the local cabinet was weird as I had a red ring and telly all dropped (so I found out later).
Anyway, this issue started around November last year, and I've been plagued with it ever since.
on 22-02-2023 22:20
Current setup:
Router - Desktop & Personal router
Here's the stats for a few hours:
To personal router's "WAN" address:
Ping statistics for 192.168.0.59:
Packets: Sent = 17253, Received = 17253, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 29ms, Average = 0ms
To internet (google dns):
Ping statistics for 8.8.8.8:
Packets: Sent = 15968, Received = 15950, Lost = 18 (0% loss),
Minimum = 14ms, Maximum = 159ms, Average = 20ms
This proves, for a fact, that my equipment is fine. It's not dropping packets at all.
The problem STILL lies with Virgin.
Now, this packet loss is MINIMAL, and I didn't experience any noticeable downtime tonight. BUT, that's not to say that this issue is "fixed". The issue generally crops up after a few days, so I will repost then.
This is just to allay queries of "oh, it's the customer's equipment". No, it currently isn't.
Also, packet loss on TBB seems to somewhat coincide with the constant ping.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3362142814a0eec418efd93397775c2d3a28a685
on 25-02-2023 13:21
Hey Nex, thanks for providing with this info and your updates.
Appreciate the above feedback, how are things looking since your last post? Have you switched to router so we can monitor the service speeds on your hub as Molly_T advised before?
Also, from our latest checks there seems to be a short-term stability issue in the area network atm so we'd like to monitor this for 24 hours and please pop back here to let us know if the issues persist after this time?
If you reach us again tomorrow afternoon we'll be able to provide more technical support in the event the problem is still present.
