Nicolag
Weak security. How to fix??
iPhones and laptops in the household keep losing WiFi connectivity. When I check it says ‘weak connection’ on both 2g and 5g connections.
forcing us to use our data 4g which of course works
resetting/disconnecting does nothing
  • 10.32K
  • 280
  • 591
Forum Team (Retired) Emma_E
Re: Weak security. How to fix??
Hi Nicolag,
Thanks for getting in touch, I am sorry to see you have been having trouble with your connection.
I have taken a look and it may help to take a look at iOS update and WiFi
If you continue to have trouble after that let us know and we will be happy to take a look for you.
All the best
Emma
