on 25-05-2021 07:30
Does anyone with more experience than me know if the hub4 allows link aggregation now?
I had no luck in modem mode, but I did mange a connection when setup as dual wan.
However that’s not exactly an ideal way to do it.
If it doesn’t, that means it’s basically impossible to get beyond 950mb on a wired connection?
That leaves 150mb unusable.
Thanks for any input.
21-10-2021 11:44 - edited 21-10-2021 11:45
I know this is a dormant thread but, in case you missed it, VM has just announced the Superhub 5 which comes with a 2.5Gbps LAN port among other things and doesn't use the flawed Intel Puma chipset. Details of when it'll be widely available are sketchy, though.
Main thread here: https://community.virginmedia.com/t5/Networking-and-WiFi/Superhub-5/td-p/4846270
Cheers.
