  • 10
blunderman
Message 1 of 16
WIFI stability and mobile wifi calling
Have Huawei phone (android 8.1) with EE as network provider.  At home wifi calls break and don't reconnect.  No issue when wifi calls switched off.  Sometimes have intermittent short hangs when accessing web sites on computers.  Have virgin hub 3 and when running network diagnostics it reports I have problems with device signal strength (all three devices including phone) and to move devices closer to hub. Devices themselves report strong signal.  I've put two devices within 1 metre and "problem" continues to be reported.  I've rebooted hub and reset to factory settings and diagnostics remain as is.
Any thoughts on whether hub 3 needs swapped out or there is another problem?
  • 10
blunderman
Message 2 of 16
Re: WIFI stability and mobile wifi calling
More info - wifi quality snapshot
VM home broadband connection quality
  • 653
  • 33
  • 45
Message 3 of 16
Hello blunderman
Thank you for posting this on our forum and welcome to the community. Apologies in the delays in getting back to you. Have you been able to speak to the team since your post? Is this something you still require assistance with?
After rebooting the Hub, have you 'forgotten' the network from the connections settings from the devices as well?
Rob
  • 8.61K
  • 884
  • 1.34K
Message 4 of 16
Post your most recent BQM.
  • 10
blunderman
Message 5 of 16
Latest graph
Have only now "forgotten" and reconnected devices.  Prior to this problems were ongoing.  Will report later if reconnection has made any further difference.
  • 8.61K
  • 884
  • 1.34K
Message 6 of 16
Ok first - just check all your coax connections are in nice and "finger" tight at the Hub and wall box and at any splitters/attenuators/etc and that the internal wiring is ok with no kinking or chaffing. Also check that all looks good with the outside cabling and wall box.
Then... if that’s all good.... Post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return. On the first page up [there should be no need to login if you have done so before] click on the “router status” icon at top right (SH2’s) or the text at bottom-middle of first page up (Hub3) and then copy/paste 3 FULL sets of data onto here – from the downstream, upstream, & network logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you.
  • 10
blunderman
Message 7 of 16
12030000002.240256 qam9
2139000000340256 qam1
31470000002.940256 qam2
41550000003.540256 qam3
51630000002.440256 qam4
61710000001.438256 qam5
7179000000-0.238256 qam6
81870000000.238256 qam7
91950000002.240256 qam8
102110000002.440256 qam10
112190000002.440256 qam11
122270000002.540256 qam12
132350000002.740256 qam13
142430000002.740256 qam14
15251000000340256 qam15
16259000000340256 qam16
17267000000340256 qam17
182750000002.240256 qam18
192830000001.740256 qam19
202910000000.940256 qam20
212990000001.540256 qam21
223070000001.740256 qam22
233150000001.740256 qam23
24323000000240256 qam24
1Locked40.9310078265803
2Locked40.9245650237886
3Locked40.3254697229771
4Locked40.9201541199831
5Locked40.3221948242084
6Locked38.9267052361835
7Locked38.9325962458752
8Locked38.6363419503903
9Locked40.3308706310422
10Locked40.3278555307423
11Locked40.3308162312090
12Locked40.3275032257562
13Locked40.9281594196241
14Locked40.3261404190125
15Locked40.9221192149771
16Locked40.3200710161837
17Locked40.9153429159611
18Locked40.3175430201800
19Locked40.9177190260085
20Locked40.9231502321684
21Locked40.9224153309332
22Locked40.9243969281122
23Locked40.3235783293299
24Locked40.3216898255658
1603000005.1512064 qam1
2394000005.1512064 qam4
3462000005.1512064 qam3
4537000005.1512064 qam2
3ATDMA0000
4ATDMA0000
  • 10
blunderman
Message 8 of 16
12/08/2019 12:56:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=:6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 12:56:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=:78:6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 12:56:30criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=78:6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 12:56:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=78:6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 12:56:32criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC 78:6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 12:56:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 13:06:32criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 13:06:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=:6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 13:24:21criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 13:24:21Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=78:6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 13:24:22criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 13:24:22Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=8:6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 14:00:32criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=:6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 14:00:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=:6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 14:01:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 14:01:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 14:02:0criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=:6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 14:02:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=6a:83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 14:20:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=83:24;CM-QOS=1.1;CM-VER=3.0;
12/08/2019 14:20:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=:83:24;CM-QOS=1.1;CM-VER=3.0;
  • 10
blunderman
Message 9 of 16
Connections were the first things I checked.  Internal tight.  External look OK.  New cable was spliced in some months ago.
  • 10
blunderman
Message 10 of 16
Notice that VM did some software updates to my router Tuesday early.  Still appraising whether changes have improved things with wifi calling.  Forum should note that downstream power levels on router stats are prone to drops.  Normally channels are between 5-6 dBmV and then see below screenshot
12030000001.540256 qam9
21390000002.740256 qam1
3147000000340256 qam2
41550000003.740256 qam3
51630000002.940256 qam4
61710000001.940256 qam5
7179000000038256 qam6
8187000000-0.238256 qam7
91950000001.740256 qam8
10211000000240256 qam10
11219000000240256 qam11
122270000002.240256 qam12
132350000002.440256 qam13
142430000002.540256 qam14
18275000000240256 qam18
192830000001.540256 qam19
202910000000.440256 qam20
212990000000.940256 qam21
223070000000.940256 qam22
233150000000.940256 qam23
243230000001.440256 qam24
1Locked40.31282318906
2Locked40.31069817716
3Locked40.31079616333
4Locked40.3841313476
5Locked40.3945618729
6Locked40.31150632415
7Locked40.91481745847
8Locked40.31560245335
9Locked40.91317124464
10Locked40.31181123828
11Locked40.31305524309
12Locked40.31169620916
13Locked40.91211015069
14Locked40.31118213492
15Locked40.3951311911
16Locked40.3902911807
17Locked40.3739312825
18Locked40.3834717542
19Locked40.3882124782
20Locked40.31086430823
21Locked40.31064228026
22Locked40.91133226399
23Locked40.31089224705
24Locked40.3971120598
drop coincides with quality degradation - see below (last spikes)
