on 02-11-2021 09:34
Virgin has the worst customer service ever, used to be brill when we first joined but now you just get passed from pillar to post or fobbed off. We've been with Virgin a decade and nothings changed this end re location of my laptop or the router in the other room, but for the past year and a half my laptop crashes sometimes 4 times a day sometimes 30+, can no longer watch work instructional videos that i need too , or listen to music without internet crashing out. Spoke to a very rude woman at Virgin who tried to flog me a booster ? When i refused she offered a new router as she said ours was old and that was the problem, I knew it wasn't, but she was so short tempered, i agreed, got a Hub 3 but nothings changed, the signal is daily unstable, worse than ever. Yesterday internet went down, a smug recorded voice at VM HQ said it was because they were "Making it better for us" ? so our post code would have problems. It came back later but ever since mine keeps dropping out after minutes, yesterday and today, I've already had to restart 5 times. There is only my mums computer and my laptop, in rooms next to each other so this situation is ridiculous, we're either told to ring, in which case you're fobbed off by someone that hasn't got a clue, or Twitter VM tells you to come here? I have an elderly mother here, I'm disabled and do charity work from home, so it's frustrating and soul destroying to waste days not getting anything done other than restarting my laptop and wifi? It never used to be like this? What's happened Virgin? Prices increase but the service is dreadful in comparison?
on 02-11-2021 09:54
Can you please post the network log and power levels from your Hub for comment? Once we have these we can try to assist with the issue.
You can also try splitting the SSID as below as it may help with the wifi disconnections.
• Access your Hub by navigating to 192.168.0.1
• Login with the default login info (on base of Hub) unless you've already updated it.
• Go to Advanced Settings > Wireless > Security
• Under Wireless Frequency 2.4GHz change the Wifi Network Name (SSID), suggest append _2 to the end.
• Repeat for the Wireless Frequency 5GHz and click on Apply changes
on 02-11-2021 11:04
If you're not technical and have cognitive problem, as i do that really doesn't help and looks like gobble-de-**bleep**, but thanks for trying.
on 02-11-2021 13:47
Virgin have bleeped a word as though I swore ? I didn't. I found this, is this what you meant?
SSID: VM1186950
Protocol: Wi-Fi 4 (802.11n)
Security type: WPA2-Personal
Network band: 2.4 GHz
Network channel: 11
Link speed (Receive/Transmit): 144/72 (Mbps)
Link-local IPv6 address: fe80::8d3:3b26:c78e:d6f4%19
IPv4 address: 192.168.0.11
IPv4 DNS servers: 194.168.4.100
194.168.8.100
Manufacturer: Qualcomm Atheros Communications Inc.
Description: Qualcomm Atheros AR956x Wireless Network Adapter
Driver version: 3.0.2.201
Physical address (MAC): **:**:**:**:**:**
on 02-11-2021 14:55
on 12-01-2022 13:10
Hi mamachill,
Thank you for your post. Our apologies that we missed this thread.
We would like to take a look into this for you. I have located your account.
And will private message you to pass some data protection.
^Martin
on 12-01-2022 13:21
Thankyou, Ah my mothers the account holder, but as a pensioner she finds it way too stressful dealing with Virgin hence why I do it, so the email would've i'm guessing gone to her? I'll have to check out her computer and get back.
on 14-01-2022 13:27
Hi mamachill,
It is a letter that has been sent out. Not an email.
^Martin
