on 05-04-2023 21:36
Hub 4 - 2 x Wi-Fi pods. The pods will not connect to the router. Customer services no help at all. Can someone please help
on 05-04-2023 23:19
Have you changed anything on your hub?
The pods only work under certain conditions.
Keep your Hub in Router Mode - Do not put the Hub into Modem Mode, as this disables the Wi-Fi and your Pods are connecting to your Hub via Wi-Fi. Likewise, if you use a third-party router it will not work because the Pods are designed to specifically connect directly with VM's Hubs only.
Do not split the SSID – If the SSID is split then the hub treats the two bands as two different standalone networks (the same as picking up your neighbours Wi-Fi when you search for a network). The Smart Wi-Fi cannot move a device between different networks.
Do not disable either bands – If both bands (2.4GHz and 5Ghz) are not switched on then the software cannot move the device for optimisation, which essentially disables the Smart Wi-Fi.
You should also ensure that Chanel Optimisation is enabled in your hub settings.
on 06-04-2023 07:06
on 06-04-2023 08:15
I haven’t changed anything on my hub. I have resetted the router to factory settings. It’s seem to be an issue with VM connect app. Where it picks up the Wi-Fi pods but won’t connect them. I have even tried placing them right by the router and also wired them to the router via Ethernet to see if that helped. Can I have an engineer to come and assess please or is there an issue with the app?
