on 14-10-2021 09:31
I have got a network attacks letter from Virgin, this has now got me worried and I’ve spent the last day checking my devices
letter headed ‘VMIS60-NETWORKATTACKS-F009348729’
i have used AVG and other AV software to check my mobile phones, iPads and laptops but haven’t found anything
THIS now worries me that it’s in my IOT devices which I have no idea how to check e.g. Fire TV cube, Alexa, Google Nest, Smart TVs etc etc
any advice appreciated as I don’t want my broadband cut off
on 14-10-2021 09:39
What is the nature of the "attack", what details did they give you to ascertain where the "threat" is coming from?
on 14-10-2021 10:03
They don’t really 😕
The letter just points you at their network attacks page -
http://virginmedia.com/networkattacks
also references that we might get help from the community pages &
just says that malware might be causing these network attacks from my network
its all very limited to help me and I have no idea how you investigate malware on IOT devices 😕
on 16-10-2021 11:49
Welcome back to the community @mezzaninedoor.
Have you followed all of the instructions on the link and have any issues been found, when doing that?
Have you noticed any issues with any of your services or devices?
Regards,
Steven_L
on 16-10-2021 15:20
I’ve not noticed any problems with IOT, devices or laptops personally
on 16-10-2021 16:08
on 18-10-2021 16:14
Thanks for getting back to us @mezzaninedoor
Were you able to follow the advice from @legacy1 and run a BQM? https://www.thinkbroadband.com/broadband/monitoring/quality
Were any issues showing on the network on your BQM?
Kind regards,
Serena
on 18-10-2021 17:41
I got a bit confused.
I don’t know what a BQM is?
on 20-10-2021 17:48
Sorry for any confusion, if you follow the link my college posted above you can set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any network dropouts. It does it 24/7 and it keeps a visual record of any/all of your network disconnections.
Tom
on 25-11-2021 16:32
I’ve set up quality monitors but I’ve not been able to determine anything worrying
i wish the letter was more specific as I have iPads connected, lightbulbs connected etc etc and I’m not very good at working out where the problem is
ive now had a second letter
ive turned web safe on as instructed, I use AVG on my laptops however I rarely have them up and running, the most used devices on my network are my fire tv and smart TVs and iPads and I just done know what to do that’s within a layman’s skill set
Tony
