on 27-11-2021 13:22
We recently upgraded our wifi from our old upc horizon wifi to the new virgin media super hub 3.0. However we are experiencing frequent wifi drops and unstable Ethernet connections. If anyone knows how to fix this I would much appreciate it.
on 27-11-2021 14:54
on 27-11-2021 19:18
Are you VM IE ? This is the VM UK forum. You need the VM IE helpline.
on 27-11-2021 19:21
I'm happy to try and help wherever you are.
Can you post the hub's status data for Downstream, Upstream and Network log? That might not show anything, but it's worth a go.
on 29-11-2021 19:49
Hello @axpresbom,
Welcome! Thanks for posting.
I am sorry for any issues with your new broadband.
Please can you confirm if you are UK based or from Ireland?
Many thanks,
