pas2018
Message 1 of 8
Virgin hub 3.0 reboots and resets itself.
My virgin hub robots itself several times a day.
It also wipes setting e.g. the ssid and password (probably all settings)
Has anyone had this problem?  Andy got any solutions / fixes?
Or been able to convince support that it is a problem they should address and offer to fix?
  • 11.05K
  • 731
  • 3.17K
Message 2 of 8
Re: Virgin hub 3.0 reboots and resets itself.
Can you post your upstream and downstream power levels..
Go to 192.168.0.1
Do NOT LOG IN- Click router status
And post Downstream and Upstream levels..
pas2018
Message 3 of 8
Here are the downstream and upstream data:
1 298750000 1.9 38 256 qam 21
2 322750000 2.7 40 256 qam 24
3 306750000 1.9 38 256 qam 22
4 282750000 1.7 38 256 qam 19
5 274750000 1.9 38 256 qam 18
6 258750000 2 38 256 qam 16
7 242750000 2 40 256 qam 14
8 234750000 2 38 256 qam 13
9 210750000 2 38 256 qam 10
10 314750000 2.2 40 256 qam 23
11 290750000 1.5 38 256 qam 20
12 266750000 2 38 256 qam 17
13 250750000 2 38 256 qam 15
14 226750000 2 38 256 qam 12
15 218750000 2.2 38 256 qam 11
16 202750000 2 38 256 qam 9
17 194750000 2.2 38 256 qam 8
18 186750000 2.2 38 256 qam 7
19 178750000 2.4 40 256 qam 6
20 170750000 2.4 38 256 qam 5
21 162750000 3 38 256 qam 4
22 154750000 3.2 38 256 qam 3
23 146750000 3 38 256 qam 2
24 138750000 3 40 256 qam 1
1 Locked 38.9 6 0
2 Locked 40.3 0 0
3 Locked 38.9 5 0
4 Locked 38.9 6 0
5 Locked 38.9 4 0
6 Locked 38.6 5 0
7 Locked 40.3 6 0
8 Locked 38.6 5 0
9 Locked 38.9 7 0
10 Locked 40.3 5 0
11 Locked 38.6 5 0
12 Locked 38.9 4 0
13 Locked 38.9 8 0
14 Locked 38.6 9 0
15 Locked 38.9 11 0
16 Locked 38.9 87 1
17 Locked 38.6 15 0
18 Locked 38.6 16 0
19 Locked 40.3 10 0
20 Locked 38.9 0 0
21 Locked 38.9 4 0
22 Locked 38.9 10 0
23 Locked 38.9 5 0
24 Locked 40.3 13 0
1 25800000 41 5120 16 qam 8
2 32600000 42.3 5120 16 qam 7
3 39400000 43 5120 16 qam 6
4 46200000 43.8 5120 16 qam 5
1 ATDMA 0 0 0 0
2 ATDMA 0 0 1 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 1 0
  • 11.05K
  • 731
  • 3.17K
Message 4 of 8
Looks okay- can you set up a BQM
 HERE
 Run it for say 24 hrs, and post the result.
pas2018
Message 5 of 8
OK, great that sounds like a good idea. I've set that up now.
pas2018
Message 6 of 8
Ok I have done the BQM for just over 24 hours. Remarkably the router stayed live for most of that time then about 40 mins ago it started to reboot itself - several times and it took a while. Then it was working OK, Then a few mins later it cut out a bit (not sure if it was rebooting) but recovered itself again - quite quickly this time... all reflected in the BQM chart: My Broadband Ping - PAS Router 01
  • 11.05K
  • 731
  • 3.17K
Message 7 of 8
Yeah thats definitely WAN side dropping out, Ill flag for staff to take a look their side.
  • 15.2K
  • 653
  • 32
Moderator (Retired) John_G
Moderator (Retired)
Message 8 of 8
Hi Pas2018,
Sorry to hear you're getting drop outs. I've just checked your connection and there's a SNR fault open under ticket F006707834 which is estimated to close 11/12/18.
Once the fault has cleared let us know if you're still seeing issues and we'll check again for you.
