Abzswann
Virgin hub 3.0 disconnected
I can connect to the internet when using the cable but the Wi-Fi is not connecting. My phone or fire stick can see the network and the signal is good but it won't actually connect. Do I need a new router? I have rebooted it several times everything looks normal.
  • 11.7K
  • 347
  • 678
Forum Team (Retired) Samantha_L
Re: Virgin hub 3.0 disconnected
Hi Abzswann,
Sorry to read you are having an issue with the wireless connection.
If you are still experiencing this problem, I can certainly take a look into this for you. As I was unable to locate your account, I have sent you a PM (purple envelope icon, right corner) with some details for you to confirm please.
Speak soon
Sam
