on 12-02-2021 12:07
I would appreciate if anyone knows how I can view devices on my network connected to my Hub 4? I am aware you can do this on the connect app for a Hub 3 but it says it is not compatible with 4 which seems odd.
Thanks.
on 12-02-2021 12:10
browse to teh hub on http://192.168.0.1 login and navigate to Connection Status - should list all connected devices there.
And yes, the hub4 is not supported by the app.
