  • 143
Greenpalmer
Dialled in
Message 1 of 15
Very poor SnR and lots of Post RS Errors
Yesterday morning something happened and I have lots of critical errors on the network log and since then the SnR has been very low and I have lots of Post RS errors.The network log and downstream data are as follows:
Time
Priority
Description
2018-09-24 09:12:37.00
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-24 09:12:50.00
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
critical
Warning!
2018-09-24 09:12:51.00
critical
Warning!
2018-09-24 09:12:52.00
critical
2018-09-24 09:12:58.00
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-24 09:16:51.00
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-24 09:18:20.00
Warning!
Warning!
MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-24 09:18:34.00
critical
2018-09-24 09:19:01.00
critical
2018-09-24 09:19:05.00
Warning!
2018-09-24 09:19:16.00
critical
2018-09-24 09:22:15.00
Warning!
2018-09-24 09:22:16.00
critical
Warning!
critical
2018-09-24 09:22:20.00
Warning!
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
36.3
43
8040
2
Locked
36.6
213
6034
3
Locked
37.3
62
6633
4
Locked
37.6
32
6707
5
Locked
36.6
46
8433
6
Locked
36.6
35
7494
7
Locked
36.3
33
7874
8
Locked
36.3
26
7811
9
Locked
36.6
28
10239
10
Locked
36.6
31
8115
11
Locked
36.6
26
7572
12
Locked
36.3
38
7922
13
Locked
34.3
7241
7139
14
Locked
35.5
401
7135
15
Locked
36.3
41
7129
16
Locked
36.3
30
2313
17
Locked
36.6
31
2377
18
Locked
36.3
81
3079
19
Locked
36.3
63
3220
20
Locked
36.3
55
2982
21
Locked
36.3
55
3266
22
Locked
35.7
95
2261
23
Locked
35.7
142
2628
24
Locked
35.7
136
2768
Any ideas what the problem is and (more importantly) what the solution is?
  • 10.37K
  • 650
  • 1.37K
jb66
Message 2 of 15
Re: Very poor SnR and lots of Post RS Errors
What fault are you experiencing?
  • 143
Greenpalmer
Dialled in
Message 3 of 15
Well that is a very reasonable question and in fact everything seems to be functioning reasonably normally.
I have made the post because I do keep an eye on the router logs and statuses and I have never seen anything like this before and am concerned that something has gone wrong.
  • 10.37K
  • 650
  • 1.37K
jb66
Message 4 of 15
The reason I asked as your SNR is the above minimum 34db If only just
  • 143
Greenpalmer
Dialled in
Message 5 of 15
My concern is that my SNR has suddenly dropped substantially and I am suddenly getting lots of post RS errors which I haven't been getting before.
Something has happened to my connection and it definitely isn't good.
  • 17.51K
  • 959
  • 7.16K
Message 6 of 15
You missed posting the column with the downstream power levels as well. (SNR is only half of the information)  As well as the upstream power levels.
Is the post RS count rising over time or is it static?
Tim
Click to learn more about VIP
Use Kudos to say thanks
  • 143
Greenpalmer
Dialled in
Message 7 of 15
Here's the power levels:
1299000000036256 qam21
23230000000.737256 qam24
33150000000.737256 qam23
43070000000.936256 qam22
5291000000-136256 qam20
6283000000-0.736256 qam19
7275000000-0.236256 qam18
8267000000036256 qam17
92590000000.236256 qam16
102510000000.236256 qam15
112430000000.236256 qam14
122350000000.236256 qam13
132270000000.235256 qam12
142190000000.535256 qam11
152110000000.536256 qam10
162030000000.736256 qam9
171950000000.936256 qam8
181870000000.936256 qam7
19179000000136256 qam6
201710000001.436256 qam5
211630000001.536256 qam4
221550000001.535256 qam3
231470000001.735256 qam2
241390000002.235256 qam1
The post RS errors don't seem to be increasing very much at the moment although I will keep an eye on them.
Also I only have two upstream channels at 16qam wheras other people seem to have four upstream channels at 64qam:
15370000048512016 qam65
23260000046.5512016 qam63
Is there something wrong here as well?
  • 17.51K
  • 959
  • 7.16K
Message 8 of 15
The power levels themselves look sweet although some of the SNR's aren't great, they're still within acceptable limits.
The @ForumTeam will take a look at this but it can take them a few days to do so.
  • 143
Greenpalmer
Dialled in
Message 9 of 15
OK ravenstar68, thanks very much
  • 143
Greenpalmer
Dialled in
Message 10 of 15
This is now getting worse - the SNR has dropped below 34 on channels 13 and 14 and the family say that Netflix has stopped working and just constantly buffers.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
299000000
-0.7
36
256 qam
21
2
323000000
-0.2
36
256 qam
24
3
315000000
-0.2
36
256 qam
23
4
307000000
-0.2
36
256 qam
22
5
291000000
-2
36
256 qam
20
6
283000000
-1.7
36
256 qam
19
7
275000000
-1.2
36
256 qam
18
8
267000000
-0.9
36
256 qam
17
9
259000000
-0.7
36
256 qam
16
10
251000000
-0.7
36
256 qam
15
11
243000000
-0.7
36
256 qam
14
12
235000000
-0.7
36
256 qam
13
13
227000000
-0.7
33
256 qam
12
14
219000000
-0.5
33
256 qam
11
15
211000000
-0.4
35
256 qam
10
16
203000000
-0.4
35
256 qam
9
17
195000000
0
36
256 qam
8
18
187000000
0
35
256 qam
7
19
179000000
0
35
256 qam
6
20
171000000
0.4
35
256 qam
5
21
163000000
0.5
35
256 qam
4
22
155000000
0.5
35
256 qam
3
23
147000000
0.7
35
256 qam
2
24
139000000
1.2
35
256 qam
1
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
36.6
43
0
2
Locked
36.3
83
0
3
Locked
36.6
54
0
4
Locked
36.6
33
0
5
Locked
36.6
62
0
6
Locked
36.3
50
0
7
Locked
36.3
42
0
8
Locked
36.3
64
0
9
Locked
36.6
81
0
10
Locked
36.6
34
0
11
Locked
36.3
39
0
12
Locked
36.3
66
0
13
Locked
33.8
46956
0
14
Locked
33.8
104449
0
15
Locked
35.7
110
0
16
Locked
35.7
91
1
17
Locked
36.3
148
7
18
Locked
35.7
153
65
19
Locked
35.5
143
52
20
Locked
35.5
147
27
21
Locked
35.7
180
2
22
Locked
35.5
212
53
23
Locked
35.7
358
60
24
Locked
35.5
921
17
