on 03-06-2021 10:26
Looks like I'm encountering the common problem on Virgin Broadband with the VPN connection for work being continually dropped throughout the day. I've been into the firewall settings and enabled PPTP and Multicast pass-through but issue still persists.
Superhub - V2.01.15 Hardware 1.03
Downstream log :-
Downstream DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) | 251000000 | 203000000 | 211000000 | 219000000 | 227000000 | 235000000 | 243000000 | 259000000 |
Lock Status(QAM Lock/FEC Sync/MPEG Lock) | Locked | Locked | Locked | Locked | Locked | Locked | Locked | Locked |
Channel ID | 15 | 9 | 10 | 11 | 12 | 13 | 14 | 16 |
Modulation | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM |
Symbol Rate (Msym/sec) | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 |
Interleave Depth | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 |
Power Level (dBmV) | 14.29 | 14.58 | 14.49 | 14.29 | 14.20 | 14.15 | 14.47 | 14.52 |
RxMER (dB) | 37.36 | 37.09 | 37.09 | 37.09 | 37.64 | 37.64 | 37.64 | 37.36 |
Pre RS Errors | 1992 | 2913 | 541 | 445 | 347 | 994 | 316 | 327 |
Post RS Errors | 298 | 286 | 277 | 282 | 295 | 953 | 280 | 293 |
Upstream US-1 US-2 US-3 US-4
Channel Type | 2.0 | 2.0 | 2.0 | 2.0 |
Channel ID | 4 | 3 | 2 | 1 |
Frequency (Hz) | 39400000 | 46200000 | 53700000 | 60300000 |
Ranging Status | Success | Success | Success | Success |
Modulation | 64QAM | 64QAM | 64QAM | 64QAM |
Symbol Rate (Sym/sec) | 5120000 | 5120000 | 5120000 | 5120000 |
Mini-Slot Size | 2 | 2 | 2 | 2 |
Power Level (dBmV) | 42.04 | 42.25 | 42.29 | 41.25 |
T1 Timeouts | 0 | 0 | 0 | 0 |
T2 Timeouts | 0 | 0 | 0 | 0 |
T3 Timeouts | 0 | 0 | 4 | 9 |
T4 Timeouts | 0 | 0 | 0 | 0 |
First Time | Last Time | Priority | Error Number | Description |
03/06/2021 09:05:38 GMT | 03/06/2021 09:05:38 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
03/06/2021 07:50:09 GMT | 03/06/2021 07:50:09 GMT | Notice (6) | 68010600 | DHCP Renew - lease parameters tftp file-******** modified |
03/06/2021 07:50:09 GMT | 03/06/2021 07:50:09 GMT | Error (4) | 68010300 | DHCP RENEW WARNING - Field invalid in response v4 option |
02/06/2021 17:59:40 GMT | 02/06/2021 17:59:40 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
02/06/2021 17:47:06 GMT | 02/06/2021 17:47:06 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
01/06/2021 10:30:14 GMT | 01/06/2021 10:30:14 GMT | Error (4) | 68010302 | DHCP WAN IP - 86.18.144.214 |
01/06/2021 10:29:38 GMT | 01/06/2021 10:29:38 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
01/06/2021 10:29:34 GMT | 01/06/2021 10:29:34 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
01/06/2021 10:29:32 GMT | 01/06/2021 10:29:32 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
01/06/2021 10:29:30 GMT | 01/06/2021 10:29:30 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
01/06/2021 10:29:22 GMT | 01/06/2021 10:29:22 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
01/06/2021 10:29:20 GMT | 01/06/2021 10:29:20 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
01/06/2021 10:29:18 GMT | 01/06/2021 10:29:18 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
01/06/2021 10:29:17 GMT | 01/06/2021 10:29:17 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
01/06/2021 10:29:15 GMT | 01/06/2021 10:29:15 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
01/06/2021 10:29:13 GMT | 01/06/2021 10:29:13 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
01/06/2021 10:29:06 GMT | 01/06/2021 10:29:06 GMT | Error (4) | 68000407 | TOD established |
Answered! Go to Answer
on 17-01-2023 17:51
I’m having the same issue and have been since may last year! My work keep pointing back to Virgin as my internet provider however I have several things running off my WiFi with no problems or complaints! However my works VPN struggles to maintain connection. Im at a complete loss as to what’s going on or what to do!
on 17-01-2023 17:59
Test VPN with hub in modem mode
on 19-01-2023 19:07
Hi @dawn_foster
Thank you for your post and welcome to our community.
I am sorry to hear about the service issues you have been having.
Please can you set up a BQM here and share the results with us so we can see what's happening with the connection?
Could you please also confirm for us if the connection is stable on Wi-Fi and Ethernet when you not connected to the VPN?
Please pop back to us when you can.
Vikki - Forum Team
on 20-01-2023 11:22
Same here, work are blaming Virgin Media. I've given up, VM don't show respect for customers who aren't technically minded or know/understand the jargon they speak so what else can one do! They also told me to have it working properly I need a business account. My partner won't switch to another provider so I'm stuck having to reset everything several times a day!
on 15-03-2023 18:35
Hello,
did you resolve this issue if so how?
thanks
on 15-03-2023 18:37
Is there any router you could recommend?
on 24-05-2023 18:57
i too am getting VPN dropouts. I have tried your support desk many times. As soon as i mention my works VPN they try to push me to Virgin Gadget Rescue.
i've had Virgin broadband for 8 years, and the dropouts are getting worse. I have had my laptop wifi card drivers updated, all my laptop software is upto date.
My works IT support have done everything they can.
When i use my mobile hotspot i dont get any dropouts at all.
Can an administrator please help me to solve this.
i have a Hub 3.
Unless i get a solution, i will have to leave when my contract ends.
on 24-05-2023 19:04
Hi planegirl.
Did you get any resolution to your issue please ?
on 26-05-2023 19:45
Hi Richieb41,
Thanks for using the Community Forums to get this issue with your VPN connection looked into, I am sorry if this has been causing some frustration 😥
I understand you can use your work laptop on a mobile hotspot with no issues, but using the Hub's WIFI causes drop outs whilst your work's VPN is active.
Can I ask whether any other devices in the home have issues connecting to the Hub's WIFI?
Have you tried connecting your work laptop to the internet via an Ethernet cable?
In most cases we can't offer support with 3rd party VPN's as the issue may not be something we can help with or it may be being caused by the VPN and not Virgin Media equipment.
But of course we will go through all kinds of checks and diagnostics to find out whether it is something we can fix on our side 🤗
Please let us know the answers to my questions and we'll continue to help.
Megan_L
14-06-2023 23:01 - edited 14-06-2023 23:03
Yup just use modem mode VM just don't test stuff they just think if I can get to google then all is good they just don't get why the one coding the router mode has problems that other 3rd party routers don't seem to have which is all down to them doing the testing and VM do not care even if we report it nothing happens for years.
And what with this hub 5x whatever they have gone and done it again by not giving the option for modem mode! We are all going to complain again when more people start using it this is a fcku joke.
