on 05-12-2022 13:40
I have to work from home reguarly and have to access my employers network via their secure VPN. I've never had a problem until we upgraded from out hub 3 to a 5. Since then, I was unable to access the network. My IT department gave some advice and from that I disabled the advanced network error search. This worked for a while but all of a sudden I'm back to square one with no access! My IT department can't help further as it's an issue with my ISP.
Any help would be appreciated so I can actually do my job!
on 05-12-2022 14:41
on 07-12-2022 14:43
Hey Rosie_J,
Welcome to the community and thanks for taking the time to post here on the forums.
I’m sorry to hear of the issues that you’re having with your connection, as you posted on Monday, I just want to check if you're still having issues connecting to your VPN at the moment?
Kind Regards,
Steven_L
on 07-12-2022 14:51
Thanks John 👍🏻
Hi Steven, yes it's still ongoing. I'm finding I have to switch my router off and back on again every time I log into my laptop - not ideal!
on 07-12-2022 15:45
on 09-12-2022 17:50
Hi Rosie_J,
Thanks for coming back to us about this issue with your VPN.
I am afraid what the other users have mentioned is true, we don't support VPN's on our network and so it would be an issue your work would need to continue to look into.
The other advice the users have given might be helpful, I am sorry that we cannot help directly with this issue though.
I wish you all the best with getting this issue resolved.
Megan_L
on 13-12-2022 06:40
What is frustrating as I didn't have an issue with my old Hub 3 but it has only started since we upgraded to a Hub 5!
I'm now in a situation where my IT dept are saying its my ISPs issue and Virgin are sati g it's my employers issue. Perhaps I'll just give up and switch to Sky or BT....
on 13-12-2022 10:47
on 13-12-2022 10:52
I've had a recent firmware update for the HUB 5, so may be worth checking your HUB stats to see if/when it occurs to see if it helps:
on 15-12-2022 11:54
Hello Rosie_J.
Just a quick message to see how things are now.
Have you checked the information given above by @carl_pearce?
Gareth_L
