on 06-12-2021 11:19
Hello,
I did ask this question but was never confirmed.
If you setup your VM router to also serve/broadcast the Guest Wifi does the VM Wifi pod also provide/serve this wifi connection? Or just the main/primary wifi setup on the VM router?
Cheers
on 08-12-2021 11:23
Hi FlashPan
That's the First time anyone has asked this question
And to be honest I will need to go away and find out for you
As its got me stumped
As soon as I find out I shall let you know
Gareth_L
on 08-12-2021 11:56
Cheers Gareth_L , appreciate that.
on 28-12-2021 19:52
Evening,
Anyone put their hand up yet to know the answer to this?
Cheers
on 28-12-2021 19:54
from memory when trialling the pods pre-release they only extended the main network not the guest
on 28-12-2021 19:58
Cheers for that. I was in the trial as well and when I asked in that forum the mod was not sure and didn't come back to me. But still interesting to know for sure. Thanks again
on 31-12-2021 09:51
Hi @FlashPan,
I can confirm that the intelligent WIFI pods will only work on the primary network.
If you need any other help we'll be here.
All the best for the New Year!
on 31-12-2021 09:55
Cheers for that.
HNY 2 U 2 🙂
31-12-2021 10:05 - edited 31-12-2021 10:06
This is another reason to invest in a proper replacement for the inadequate WiFi provided by Virgin.
