  • 710
  • 40
  • 47
Message 41 of 49
Re: VM WiFi booster disappointment - not working
Hi Je51cat,
Thanks for your post and welcome to the community.
I'm sorry to hear you're having issues with setting up your second booster, and I can appreciate you'd like to get them up and running as soon as possible.
Are both of the boosters ones that have been provided by us? Have you been able to check our troubleshooting page here?
Melissa
  • 15
  • 10
Je51cat
Message 42 of 49
Yes both provided by virgin
yes done all the trouble shooting
currently given up
  • 510
  • 21
  • 47
Message 43 of 49
Hi Je51cat,
Thank you for coming back to us.
I am sorry to hear that you are unable to set up your 2nd booster.
Is the socket where you are putting the booster on the same wiring loop as the booster plugged into your router?
Kind regards
Paul.
  • 15
  • 10
Je51cat
Message 44 of 49
I have no idea about wiring loops
  • 510
  • 21
  • 47
Message 45 of 49
For the booster to work it uses the electric wiring, if the two sockets aren't connected the booster won't work. ^PDe
  • 15
  • 10
Je51cat
Message 46 of 49
Yes it must be on the same loop as i set the first booster up on that plug and that on e works great it’s the second booster won’t pair up it’s a nightmare
  • 510
  • 21
  • 47
Message 47 of 49
Hi Je51cat,
Thank you for coming back to me.
It sound like it may be faulty, I advise speaking to our faults team on 0345 454 1111 option 1 then option 3, who will be able to get this swapped for you if this is the case.
Kind regards
Paul.
  • 15
  • 10
Je51cat
Message 48 of 49
This is already a replacement one we’ve tried that already
  • 1.36K
  • 70
  • 179
Message 49 of 49
Hello Je51cat
I think we may need to get an engineer to come out.
Before we do
Can you try pairing the second booster in the same room please see if that helps
It may well be the Internal wiring that is on a different circuit
Gareth_L
