on 21-04-2023 10:07
Hi people,
I've decided to re-post this as the forum incorrectly marked my last post as 'answered'.
I recently installed a new VM Hub 5, but just as the previous hub (VM Hub 3) the connection is still being dropped. It last happened in the early hours of yesterday morning - and again around 28 hours prior. It is a regular occurrence.
I wondered if anyone can please tell me; is there anything suspicious in the log files below? Either way, I guess my next step is to log this with Virgin Media and go from there?
Thanks..
Error in Network log file reads as follows:
Time/Priority/Description
20-04-2023 02:52:08 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER =3.1; |
20-04-2023 02:52:08 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 02:52:01 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
20-04-2023 02:51:55 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 02:51:55 | warning | Dynamic Range Window violation |
20-04-2023 02:51:55 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 02:51:55 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 02:51:50 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 02:51:46 | notice | TLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 02:51:44 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 02:51:42 | notice | Honoring MDD; IP provisioning mode = IPv4 |
20-04-2023 02:51:32 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 02:51:15 | critical | Cable Modem Reboot via RG reboot command |
Item/Status/Comments
Acquired Downstream Channel(Hz) | 306000000 | Locked |
Ranged Upstream Channel(Hz) | 49600000 | Ranged |
Provisioning State | Online | Operational |
0 | 49600000 | 42.3 | 5120 | QAM 64 | 1 |
1 | 43100000 | 42 | 5120 | QAM 64 | 2 |
2 | 36600000 | 42.3 | 5120 | QAM 64 | 3 |
3 | 30100000 | 41.8 | 5120 | QAM 64 | 4 |
4 | 23600000 | 41.8 | 5120 | QAM 64 | 5 |
1 | 306000000 | 6.2 | 39 | QAM 256 | 22 |
2 | 138000000 | 2.8 | 37 | QAM 256 | 1 |
3 | 146000000 | 2.5 | 37 | QAM 256 | 2 |
4 | 154000000 | 2.7 | 38 | QAM 256 | 3 |
5 | 162000000 | 2.9 | 38 | QAM 256 | 4 |
6 | 170000000 | 3.1 | 38 | QAM 256 | 5 |
7 | 178000000 | 3.4 | 38 | QAM 256 | 6 |
8 | 186000000 | 3.6 | 38 | QAM 256 | 7 |
9 | 194000000 | 4 | 38 | QAM 256 | 8 |
10 | 202000000 | 4.3 | 38 | QAM 256 | 9 |
11 | 210000000 | 4.1 | 38 | QAM 256 | 10 |
12 | 218000000 | 3.8 | 38 | QAM 256 | 11 |
13 | 226000000 | 3.7 | 38 | QAM 256 | 12 |
14 | 234000000 | 3.5 | 38 | QAM 256 | 13 |
15 | 242000000 | 3.8 | 38 | QAM 256 | 14 |
16 | 250000000 | 4.3 | 39 | QAM 256 | 15 |
17 | 258000000 | 4.8 | 39 | QAM 256 | 16 |
18 | 266000000 | 5.5 | 39 | QAM 256 | 17 |
19 | 274000000 | 5.7 | 39 | QAM 256 | 18 |
20 | 282000000 | 5.4 | 39 | QAM 256 | 19 |
21 | 290000000 | 5.7 | 39 | QAM 256 | 20 |
22 | 298000000 | 6.1 | 39 | QAM 256 | 21 |
23 | 314000000 | 6.2 | 39 | QAM 256 | 23 |
24 | 322000000 | 6.3 | 39 | QAM 256 | 24 |
25 | 330000000 | 6.6 | 40 | QAM 256 | 25 |
26 | 338000000 | 7.1 | 40 | QAM 256 | 26 |
27 | 346000000 | 6.8 | 40 | QAM 256 | 27 |
28 | 354000000 | 6.4 | 40 | QAM 256 | 28 |
29 | 362000000 | 6.6 | 40 | QAM 256 | 29 |
30 | 370000000 | 6.8 | 40 | QAM 256 | 30 |
31 | 378000000 | 6.9 | 40 | QAM 256 | 31 |
on 21-04-2023 10:57
"the forum incorrectly marked my last post as 'answered'."
Careful ... that occurs if you mark a response as a helpful answer.
on 21-04-2023 11:15
I can't see any issues from that - there are DRW warnings but that's pretty normal - someone else may spot something however.
Are there any errors showing in the log (on another page)?
on 21-04-2023 11:47
Yes, I realised that this was the case after marking a post as helpful. It'd be nice if the forum warned you that doing so also marked it as 'answered'.
on 21-04-2023 11:48
There are more errors, but they're all pretty similar, should I post the entire log?
on 21-04-2023 11:56
The Hub log doesn't seem to keep much of a history, it looks like it's constrained by the number of entries, rather than time-based.
Anyway, for what it's worth, here's all of it:
21-04-2023 09:15:07 | warning | Dynamic Range Window violation |
21-04-2023 09:15:07 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 08:37:11 | warning | Dynamic Range Window violation |
21-04-2023 08:37:11 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 07:33:37 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 07:33:37 | warning | Dynamic Range Window violation |
21-04-2023 04:05:57 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 04:05:57 | warning | Dynamic Range Window violation |
21-04-2023 02:20:47 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 02:20:47 | warning | Dynamic Range Window violation |
21-04-2023 01:09:34 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 01:09:34 | warning | Dynamic Range Window violation |
20-04-2023 23:52:41 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 23:52:41 | warning | Dynamic Range Window violation |
20-04-2023 22:49:07 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 22:49:07 | warning | Dynamic Range Window violation |
20-04-2023 21:42:33 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 21:42:33 | warning | Dynamic Range Window violation |
20-04-2023 21:30:15 | warning | Dynamic Range Window violation |
20-04-2023 21:30:15 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 17:08:40 | warning | Dynamic Range Window violation |
20-04-2023 17:08:40 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 15:41:28 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 15:41:28 | warning | Dynamic Range Window violation |
20-04-2023 14:34:14 | warning | Dynamic Range Window violation |
20-04-2023 14:34:14 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 12:17:47 | warning | Dynamic Range Window violation |
20-04-2023 12:17:47 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 11:06:33 | warning | Dynamic Range Window violation |
20-04-2023 11:06:33 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-04-2023 09:59:00 | warning | Dynamic Range Window violation |
20-04-2023 09:59:00 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 21-04-2023 12:03
The only other hint is on the status page:
Item Status Comments
I can't be certain, but is it possible that the upstream previously stated 'Locked' and has now changed (and is related to the errors in my previous post)?
on 22-04-2023 11:37
Another dropout at 23:51last night:
22-04-2023 11:02:38 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-04-2023 10:17:24 | warning | Dynamic Range Window violation |
22-04-2023 10:17:24 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-04-2023 08:22:34 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-04-2023 08:22:34 | warning | Dynamic Range Window violation |
22-04-2023 06:47:23 | warning | Dynamic Range Window violation |
22-04-2023 06:47:23 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-04-2023 00:55:06 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-04-2023 00:55:06 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 23:51:30 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 23:51:30 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 22:08:53 | warning | Dynamic Range Window violation |
21-04-2023 22:08:53 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 20:47:41 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 20:47:41 | warning | Dynamic Range Window violation |
21-04-2023 19:45:07 | warning | Dynamic Range Window violation |
21-04-2023 19:45:07 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 16:52:23 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 16:52:23 | warning | Dynamic Range Window violation |
21-04-2023 13:12:44 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-04-2023 13:12:44 | warning | Dynamic Range Window violation |
on 22-04-2023 11:39
on 22-04-2023 19:02
More data:
22-04-2023 17:40:41 | warning | Dynamic Range Window violation |
22-04-2023 17:40:41 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-04-2023 16:21:49 | warning | Dynamic Range Window violation |
22-04-2023 16:21:49 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-04-2023 14:52:57 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-04-2023 14:52:57 | warning | Dynamic Range Window violation |
