on 16-09-2022 11:44
Hello,
I have always run my V6 in Router mode and recently decided to expand my network due to some room changes.
I have added a Net gear GS308E which is wired directly to the V6 hub (port 1 on both devices), the net gear has various bits connected to it including a PC, NAS, Google Nest Wi-Fi Router etc.
As i type this the V6 Hub is in Router mode, providing internet to the switch and all connected devices with no issues. When I enable modem mode on the V6, it reboots, the status light goes red, connectivity goes down.
I have done a quick search and to pre-empt the question, yes the V6 is warm/hot.
Factory reset on the Hub (to put it back into modem mode) and the switch and everything works...
Would appreciate any advice on how i can get the V6 to run in modem mode, with the setup above and work!
16-09-2022 11:47 - edited 16-09-2022 11:48
You need a type of NAT to map source MAC's of devices to one MAC of your one WAN IP so you need to look at a router typically.
on 16-09-2022 12:13
Any chance you could elaborate on that a little please mate?
16-09-2022 13:52 - edited 16-09-2022 13:54
Modem mode will not work with many devices each with a different MAC the hub in modem mode only allows one source MAC for one WAN IP. You need to look at getting a home router.
https://www.amazon.co.uk/RT-AX55-Dual-band-MU-MIMO-AiProtection-Adaptive/dp/B09BZLRQPY/ref=sr_1_7?dc...
on 16-09-2022 14:52
GS308E Is a network switch only, it’s not a router. The only thing that you can connect into the VM hubs when in modem mode is a router, the switch can then be plugged into that router. When a hub3 is in modem mode the LED will be magenta, this can look red to some people.
