Sywater
  • 7
Message 1 of 5
Using your own router - not working
looking to use my own router (specifically a Fritzbox 7530) with the Hub 4. I have the hub in modem mode & fritzbox connected to the first LAN port on the hub but it won’t work. The 7530 says PPoE negotiation failed.
Anyone here using a 7530, if so how do you have it configured?
thanks
Simon
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 2 of 5
Re: Using your own router - not working
The connection type should be Dynamic IP - Not PPoE
  • 24.03K
  • 2.54K
  • 4.36K
Message 3 of 5
And follow this sequence..
Disconnect all cables from your new router (or Mesh first unit) and unplug it. Put the VM Hub into modem mode ( https://www.virginmedia.com/help/virgin-media-hub-modem-mode ) and wait for the base light to turn magenta/purple (on a Hub3 - but not on a Hub4!). Once it’s in modem mode, the VM hub “MUST” then be powered off. Then, set up your own router/Mesh with the WAN port set to be in DHCP (& Nat) mode, it may be pre-set that way anyway. Make sure it’s fully initialised (leave 5 min) and then put in the WAN cable to the VM hub. NOW… power up the VM hub and you should get a connection. This order only needs to be done the first time you connect the router to the VM hub.
  • 3.2K
  • 249
  • 696
Message 4 of 5
@Sywater wrote:
looking to use my own router (specifically a Fritzbox 7530) with the Hub 4. I have the hub in modem mode & fritzbox connected to the first LAN port on the hub but it won’t work. The 7530 says PPoE negotiation failed.   <snip>
EDIT - Looks like this Router does not support cable connections, only xDSL.  It may work with the Hub 4 in router mode, but that's far from ideal.
Sywater
  • 7
Message 5 of 5
Many thanks, finally worked after powering down the hub (once in modem mode) and following your details. Thanks!
