on 03-11-2021 19:33
I have switched to Modem Mode, as the VM WiFi signal is much weaker than my three separate routers, all or which are connected to the Hub3 via ethernet cables atached to a Netgear router. Theye were all working in Router Mode. After switching to Modem Mode, the ethernet cables are working and providing internet access. The WiFi routers connect to devices, but none of them are providing internet access.
Answered! Go to Answer
on 03-11-2021 19:59
@nmearing wrote:I have switched to Modem Mode, as the VM WiFi signal is much weaker than my three separate routers, all or which are connected to the Hub3 via ethernet cables atached to a Netgear router. Theye were all working in Router Mode. After switching to Modem Mode, the ethernet cables are working and providing internet access. The WiFi routers connect to devices, but none of them are providing internet access.
Firstly if you have 3 routers only one of them should be setup as a router, others should be in bridge mode when in hub is in modem mode. If running the hub in router mode all you own routers should be in bridge mode.
How to put a VM hub into modem mode, not published by VM probably because they don’t want you to use it and use their pods.
1) Access your hub on 192.168.0.1, sign on and put it into modem mode. On the Hub3 the bottom LED will change to magenta. Best done from a wired connection.
2) Turn off the hub and disconnect any Ethernet cables
3) Fully initialise your own router and make sure the WAN port is set to DHCP
4) Connect your router to the VM hub with an Ethernet cable, Cat5e or Cat6, any higher specification is a waste of money
5) Turn on the VM hub.
6) You should now be able to access the internet and the hub will now be on 192.168.100.1
on 03-11-2021 19:59
on 03-11-2021 21:48
Thanks. Very helpful. In case it makes a difference, I have 6 ethernet cables that terminate by the hub. They are connected to the hub via a Netgear GS208 8 port router. We have 3 Dlink WiFi routers, each connected to an ethernet cable, 2 downstairs and 1 upstairs. Until I switched to Modem Mode on the hub they were providing excellent WiFi service, usually around 200 Mb/s. Now none of them give internet access, even though they connect to laptops and phones. The ethernet sockets still provide internet access, but only to one device at a time - initially to a laptop and then the smart TV .
03-11-2021 21:57 - edited 03-11-2021 22:00
Only one port will work on the hub by one source MAC for one WAN IP that you have a setup to NAT off like a home router you can't use a simple switch to the hub in modem mode because many source MAC's will be in play.
on 03-11-2021 22:27
Are you saying that it is impossible to use the hub 3 in Modem Mode and have three WiFi routers connected to it via Ethernet cables?
on 03-11-2021 22:46
Correct. A modem can’t act as a router. You will need to get one of your routers, the one connected to the Modem Mode Hub, to act as the routing device and connect the other two to its Ethernet ports .
03-11-2021 23:34 - edited 03-11-2021 23:35
@nmearing wrote:Are you saying that it is impossible to use the hub 3 in Modem Mode and have three WiFi routers connected to it via Ethernet cables?
Three routers doing NAT each with a different MAC to the hub in modem mode can't work their can be a way with a VLAN switch and if the routers do the same DHCP discover/request out the same MAC to work this isolates the network but most people have one router to the hub and you connect other stuff to that router.
on 04-11-2021 08:02
I thought that is what I had done. There's only one Ethernet cable connected to the hub which goes to a Netgear GS208 router. The 6 ethernet cables for the house network are connected to the Netgear router. Each of the 3 WiFi routers is connected via a socket at the other end of the cable. I am still puzzled as to why this network arrangement worked when the hub was in Router Mode, but doesn't in Modem Mode.
on 04-11-2021 08:13
The Netgear GS208 is not a router, it’s a dumb (unmanaged) switch. In router mode, your arrangement works because the VM hub is doing the routing and NAT functions. In modem mode you need to arrange it differently.
Remove the GS208, take one of your real routers and connect it’s WAN port to the VM hub. Connect the switch to one of the LAN ports on the router and everything else to unused ports on this switch. It would be best (although not essential) to have the other two router turned into access point mode (or whatever that model calls it) otherwise you can get unwanted IP address clashes and weird routing issues between devices.
on 04-11-2021 08:50
Would it make sense to replace the Netgear switch with an 6/8 port switch **bleep** router? WiFi routers are much bigger, I think, and there is limited space near the hub and ethernet cable terminations. If so, can you recommend a switch **bleep** router?
