on 20-10-2022 06:14
I recently set up a bt super hub 2 as an access point to get better Wi-Fi coverage around the house. Followed some instructions on here. Didn’t change anything on the VM hub 3. Switched off dhcp on the bt hub, changed the ip address on bt hub to one just below the VM hub range 192.168.0.9. Switched off firewall on bt hub. Changed the ssid on bt hub to a similar one as the vm hub but not the same. Changed the password on the bt hub to match the vm hub. So now I have 2 Wi-Fi points to connect to. If I change the bt hub ssid to match the vm hub, will that cause any issues and would I simply switch between the vm hub and bt hub depending where about in the house I am?
