on 27-10-2022 09:11
There was a planned outage yesterday in area 31 and ever since then my cable connection has been basically unusable.
My download speeds are fine, although tests take a long time to start. My upload speeds are around (and often less than) 0.1 Mbps. The consequence is that a lot of stuff times out, and video (even voice) calls are out of the question. This behaviour can easily be explained by the graph below:
Just been on the phone to support, and they can't see a problem. We went through the usual nonsense of "maybe websites are slow to load because lots of people are using them", and switching to VM's own router instead of mine. Of course it made no difference. The support script seems to focus entirely on download speeds and completely ignores upload.
It's been escalated, and I have a ticket number. I'm posting this here to a) vent a bit and b) be able to point to this graph (and complaint) in the future.
on 27-10-2022 09:22
Router logs:
Downstream:
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
38 | 435000000 | 4.5 | 38.6 | QAM256 | 38 |
8 | 195000000 | 4.9 | 39 | QAM256 | 8 |
9 | 203000000 | 4.6 | 39 | QAM256 | 9 |
10 | 211000000 | 4.6 | 39 | QAM256 | 10 |
11 | 219000000 | 4 | 39 | QAM256 | 11 |
12 | 227000000 | 2.9 | 38.6 | QAM256 | 12 |
13 | 235000000 | 2.3 | 39 | QAM256 | 13 |
14 | 243000000 | 3.4 | 39 | QAM256 | 14 |
15 | 251000000 | 4 | 38.6 | QAM256 | 15 |
16 | 259000000 | 4.2 | 38.6 | QAM256 | 16 |
17 | 267000000 | 4.1 | 38.6 | QAM256 | 17 |
18 | 275000000 | 4.2 | 38.6 | QAM256 | 18 |
19 | 283000000 | 4.5 | 39 | QAM256 | 19 |
20 | 291000000 | 5.5 | 38.6 | QAM256 | 20 |
21 | 299000000 | 5.7 | 39 | QAM256 | 21 |
22 | 307000000 | 6.2 | 38.6 | QAM256 | 22 |
23 | 315000000 | 7 | 38.6 | QAM256 | 23 |
24 | 323000000 | 7.4 | 39 | QAM256 | 24 |
25 | 331000000 | 5.7 | 39 | QAM256 | 25 |
26 | 339000000 | 4.4 | 39 | QAM256 | 26 |
27 | 347000000 | 4.3 | 39 | QAM256 | 27 |
28 | 355000000 | 4.6 | 39 | QAM256 | 28 |
29 | 363000000 | 4.7 | 38.6 | QAM256 | 29 |
30 | 371000000 | 4.3 | 39 | QAM256 | 30 |
31 | 379000000 | 4.4 | 39 | QAM256 | 31 |
32 | 387000000 | 4.6 | 39 | QAM256 | 32 |
33 | 395000000 | 5 | 39 | QAM256 | 33 |
34 | 403000000 | 4.9 | 38.6 | QAM256 | 34 |
35 | 411000000 | 5 | 39 | QAM256 | 35 |
36 | 419000000 | 5.4 | 39 | QAM256 | 36 |
37 | 427000000 | 4.7 | 39 | QAM256 | 37 |
Channel | Lock Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
38 | Locked | 38.605377 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 38.983261 | 0 | 0 |
11 | Locked | 38.983261 | 0 | 0 |
12 | Locked | 38.605377 | 0 | 0 |
13 | Locked | 38.983261 | 0 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.605377 | 0 | 0 |
16 | Locked | 38.605377 | 0 | 0 |
17 | Locked | 38.605377 | 0 | 0 |
18 | Locked | 38.605377 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 38.605377 | 0 | 0 |
21 | Locked | 38.983261 | 0 | 0 |
22 | Locked | 38.605377 | 0 | 0 |
23 | Locked | 38.605377 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
25 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 38.983261 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 38.605377 | 0 | 0 |
30 | Locked | 38.983261 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
32 | Locked | 38.983261 | 0 | 0 |
33 | Locked | 38.983261 | 0 | 0 |
34 | Locked | 38.605377 | 0 | 0 |
35 | Locked | 38.983261 | 0 | 0 |
36 | Locked | 38.983261 | 0 | 0 |
37 | Locked | 38.983261 | 0 | 0 |
on 27-10-2022 09:22
Upstream:
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 36600000 | 46 | 5120 KSym/sec | 64QAM | 3 |
2 | 30100000 | 45.8 | 5120 KSym/sec | 64QAM | 4 |
3 | 43100000 | 46.3 | 5120 KSym/sec | 64QAM | 2 |
4 | 23600000 | 45.8 | 5120 KSym/sec | 64QAM | 9 |
5 | 49600000 | 46.8 | 5120 KSym/sec | 64QAM | 1 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 2 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 27-10-2022 17:08
on 27-10-2022 17:21
And here's my current hub logs.
Time | Priority | Description |
Tue 18/10/2022 18:35:48 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 19/10/2022 02:03:17 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 19/10/2022 17:28:51 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 20/10/2022 04:22:16 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 21/10/2022 16:31:14 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 23/10/2022 16:22:17 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 23/10/2022 17:13:56 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 24/10/2022 00:47:41 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 26/10/2022 09:03:06 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 26/10/2022 09:03:10 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 26/10/2022 09:06:01 | 3 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:21 | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:21 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:36 | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:36 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:50 | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:50 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:02:18 | 4 | Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:02:44 | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:02:45 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 26/10/2022 10:35:26 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 26/10/2022 12:12:44 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 26/10/2022 12:12:58 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:02:48 | 3 | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:03:12 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 26/10/2022 17:06:37 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 26/10/2022 19:13:12 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:22 | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:22 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 26/10/2022 19:54:14 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 26/10/2022 20:12:37 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:37 | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:37 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 28-10-2022 11:46
I'm so annoyed and Virgin Media. I spoke to a second (and admittedly much better) support agent yesterday evening and I at least have an engineer booked. However, I have to wait until next Thursday and I very much doubt they'll be able to do anything to resolve this. Hopefully they can at least confirm that it is definitely an upstream problem.
I also genuinely don't understand how VM's own diagnostics can't detect a problem like this, when third party tools like the thinkbroadband.com monitor clearly show my connection is a mess. What are they even testing for?!
on 30-10-2022 17:34
Hey @rsherhod, thanks for the reply on the forums.
I'm sorry to see the issues with the connection.
I do apologise that no one had noticed this, I've had a look on the system and a reading couldn't even be made.
Looking at the graphs - this definitely does require an engineer appointment.
Let's see how it goes Thursday with the appointment.
Kind regards,
Ilyas.
on 01-11-2022 16:02
Thank you for looking into this and acknowledging that there's definitely a problem.
Do you know if I'll be able to claim some form of compensation for this lost connection. I have had to use my mobile phone as a wifi hotspot and I've already burned through a data top up, just doing video calls for work.
on 03-11-2022 18:23
Hello rsherhod,
Just a quick message to see how todays visit went?
What did the Technician advise?
How are things looking now?
Gareth_L
