I can’t remember off the top of my head if that EE router has a true WAN port. Possibly, maybe not.
It’s the type enabled for Fibre modems, right?
Try changing the IP address to, say, 182.168.0.2 and see if it connects with Virgin hub in router mode.
One way or another you need DHCP connection on the WAN side if using with VM hub in modem mode.
I use a BT Smart hub as an additional AP, but it won’t work as the router with VM hub in modem mode - I use a third party router instead
No disrespect, but you probably need more skills to sort it out, if at all possible.
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
