Privster
  • 5
Message 1 of 8
Upstream and downstream dBmV and dB
Hi all,
I receive numerous (2-10) dropouts of WiFi and Ethernet each night with my Hub 3.0. I'm here because I've tried every network diagnosis I could find, and out of luck!
I'll attach the upstream and downstream levels, and please let me know what the next step will be to have this situation fixed. Also, I'm on the M200 broadband.
Thanks!
gary_dexter
  • 28.92K
  • 1.77K
  • 3.78K
Message 2 of 8
Re: Upstream and downstream dBmV and dB
Post the network, upstream and downstream logs from the hubs admin pages back here as text
Privster
  • 5
Message 3 of 8
Sorry, where do I find these?
gary_dexter
  • 28.92K
  • 1.77K
  • 3.78K
Message 4 of 8
They're the ones you've already posted, and the rest of the tabs...
Privster
  • 5
Message 5 of 8
Cable Modem Status
Item Status Comments
402750000
Locked
Ranged Upstream Channel (Hz)
53700088
Locked
Provisioning State
Online
1 402750000 2.7 40 256 qam 30
2 202750000 3.7 40 256 qam 9
3 210750000 3.5 38 256 qam 10
4 218750000 3.4 40 256 qam 11
5 226750000 2.7 38 256 qam 12
6 234750000 2.5 40 256 qam 13
7 242750000 2.5 40 256 qam 14
8 250750000 2.7 40 256 qam 15
9 258750000 3 40 256 qam 16
10 266750000 3.2 40 256 qam 17
11 274750000 3.5 40 256 qam 18
12 282750000 3.7 40 256 qam 19
13 290750000 3.7 40 256 qam 20
14 298750000 3.9 38 256 qam 21
15 306750000 4 40 256 qam 22
16 314750000 4.3 40 256 qam 23
17 322750000 4.5 40 256 qam 24
18 330750000 4.5 40 256 qam 25
19 370750000 3.2 40 256 qam 26
20 378750000 3.2 40 256 qam 27
21 386750000 3 40 256 qam 28
22 394750000 2.9 40 256 qam 29
23 410750000 2.7 40 256 qam 31
24 418750000 2.5 40 256 qam 32
1 Locked 40.3 6 0
2 Locked 40.3 6 0
3 Locked 38.9 7 0
4 Locked 40.3 9 0
5 Locked 38.9 6 0
6 Locked 40.3 8 0
7 Locked 40.3 6 0
8 Locked 40.3 11 0
9 Locked 40.3 7 0
10 Locked 40.3 6 0
11 Locked 40.3 8 0
12 Locked 40.3 7 0
13 Locked 40.9 4 0
14 Locked 38.9 21 0
15 Locked 40.3 5 0
16 Locked 40.9 7 0
17 Locked 40.3 15 0
18 Locked 40.3 1 0
19 Locked 40.3 1 0
20 Locked 40.9 4 0
21 Locked 40.3 5 0
22 Locked 40.3 8 0
23 Locked 40.3 6 0
24 Locked 40.3 8 0
1 53700088 45.3 5120 32 qam 2
2 39400000 45 5120 64 qam 4
3 46200000 45.3 5120 64 qam 3
4 60300039 45.5 5120 64 qam 1
1 ATDMA 0 0 1 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0
0
Refresh data
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID 355022
Max Traffic Rate 230000061
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 355021
Max Traffic Rate 22000061
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
22/01/2021 09:14:34 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/01/2021 22:45:40 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/01/2021 22:45:8 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 01:14:28 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 01:05:7 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 15:26:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 05:55:45 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 08:30:42 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 04:34:57 notice SW download Successful - Via NMS
14/01/2021 04:33:8 notice SW Download INIT - Via NMS
11/01/2021 07:14:37 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 21:05:59 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 19:14:37 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 00:18:34 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/2021 07:14:37 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/2021 04:59:24 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 19:14:37 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 07:57:54 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 14:48:58 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Privster
  • 5
Message 6 of 8
Any help please?
Privster
  • 5
Message 7 of 8
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Message 8 of 8
The only thing i can see wrong with your logs/stats is that one of your upstream channels is only at 32 QAM, they should all be 64. I don’t think that that wouldn’t explain all of the dropouts though...
you say it’s on both Ethernet and WiFi?
can you set up a BQM please - post a sharing link to you live graph back here...
