  • 9
Dan95
Message 1 of 8
Upload Speed Drops At Certain Times
Hello,
I'm on a wired connection, and I have the VIV 350 package that advertises 21MBPS upload.
I stream daily on twitch.tv. Each day at least once a stream my upload speed drops to 2-3mbps at most, for anything between 5m to an hour. The rest of the time it works perfectly. Speed tests show anything from 2mbps to 8mbps upload during these times, but when this is happening my speeds are all over the place.
Some observations: Certain times seem worse. Recently it's been around 5:30pm that I've had this problem. About a month ago it was around 7pm. This could simply having something to do with the amount of time I've been streaming. I upload at around 6mbps. I also understand that certain times have more users and thus I should expect slower speeds, but in my case is goes from 100% to barely usable, and then is fine again.
Does virgin media still throttle customers based on how much they're uploading? I've talked to customer support three times and all they've told me is that everything is fine on their end and that they don't guarantee a certain upload speed. While I understand that, I think this is a completely separate issue since it's so bad for a short amount of time and perfect the rest of the time.
Any help would be appreciated. I've attached an image of my broadcast uploads showing the issue.
Dan
  • 3.63K
  • 304
  • 1.06K
Dave_cq
Community elder
Message 2 of 8
Re: Upload Speed Drops At Certain Times
VM state that they do not throttle download or upload ...
https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030...
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 9
Dan95
Message 3 of 8
Good to know it's not that at least. Definitely feels like I'm being throttled but if they don't do that anymore I still have no idea what's causing my problems.
  • 7.24K
  • 756
  • 1.13K
Legend
Message 4 of 8
Check all your coax connections are in nice and "finger" tight at the Hub and wall box and at any splitters/attenuators/etc and that the internal wiring is ok with no kinking or chaffing (rabbit chews!).  Also check that all looks good with the outside cabling and wall box.
 If that’s all good.... post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL box type in  http://192.168.0.1  (or http://192.168.100.1 - if in modem mode) and hit return.   On the page [there should be no need to login] click on the “router status” text at bottom middle of first page up and then copy/paste 3 sets of data onto here - the downstream, upstream, &  network logs.  Don't worry about the formatting it can be easily read, but try to avoid using screen shots & don’t include personal data or mac addresses - blank them out.
  • 9
Dan95
Message 5 of 8
Hey, I tightened everything as best as I could. Here's the data hopefully it's readable. The problem persists despite the tightening.
I think I've hidden all sensitive information. All help is greatly appreciated this problem is seriously hindering my use of our internet. Thank you once again.
The downstream/upstream data i've copied and pasted,
Dan
11867500002.738256 qam7
24427500004.138256 qam30
3434750000438256 qam29
4426750000440256 qam28
5418750000440256 qam27
6410750000438256 qam26
7402750000440256 qam25
83227500003.240256 qam24
9306750000340256 qam22
102987500002.938256 qam21
112907500002.738256 qam20
122827500002.238256 qam19
132747500002.238256 qam18
142667500002.238256 qam17
152587500002.438256 qam16
162507500002.438256 qam15
172427500002.538256 qam14
182347500002.438256 qam13
192267500002.538256 qam12
202187500002.738256 qam11
212027500002.738256 qam9
221947500002.738256 qam8
23314750000340256 qam23
24210750000338256 qam10
1Locked38.920973472
2Locked38.943228301
3Locked38.945559588
4Locked40.341549979
5Locked40.937099812
6Locked38.932689374
7Locked40.331609910
8Locked40.318406717
9Locked40.318397480
10Locked38.919897358
11Locked38.918985813
12Locked38.919005850
13Locked38.921705744
14Locked38.922084986
15Locked38.921445178
16Locked38.916675256
17Locked38.620025191
18Locked38.919355227
19Locked38.915305079
20Locked38.619144731
21Locked38.94592952181
22Locked38.919533221
23Locked40.320217413
24Locked38.618273698
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13580000040.8512064 qam2
24580000042512064 qam1
35370000044.8512064 qam4
42740000039.8512064 qam3
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
2ATDMA0020
3ATDMA0060
4ATDMA0030
  • 7.24K
  • 756
  • 1.13K
Legend
Message 6 of 8
Others more qualified should comment, but power levels & SNR are in spec but there are a lot of postRS errors - these could be cumulative over a long period. So switch the Hub off of for 5 minutes and reboot it and then after 24 hours recheck and repost that data.
  • 9
Dan95
Message 7 of 8
Hello,
First of all thanks for your extremely quick reply.
I actually rebooted my hub two days ago and I had the issue shortly after, yesterday and today. It's not permanently like this though, only about 10-30% of the time. I could likely check my router status when it's working perfectly and post excellent results, I'm just trying to figure out why this randomly happens for 10m to an hour at least once a day.
  • 15.2K
  • 653
  • 32
Moderator (Retired) John_G
Moderator (Retired)
Message 8 of 8
Hi Dan95,
Looking at the stats you've posted for the most part everything looks fine. I have tried to check things from this side but was unable to locate your account to investigate further.
I've just sent you a private message requesting some information so I can check further.
