on 20-05-2023 17:31
on 22-05-2023 19:29
Hi @Doddsy19 thanks for your post here in the Community, although we're sorry to hear of the concerns you've raised here.
We've ran some checks here and there doesn't appear to be any issues on the line such as localised outages for example.
How are things since your post, have things stabilised over the weekend?
Do you know if this happens over a wired connection too, or is it WiFi only?
If it's WiFi, we'd advise that our WiFi Pods as shown here may help you. Please let us know if you need any further help!
Many thanks
on 22-05-2023 19:29
Many thanks
on 23-05-2023 00:28
Speed slow on both wifi and ethernet approx speed 350mb. On both
on 23-05-2023 15:11
Did you upgrade to 1GB from 350? If so - have you looked in the Hub's settings to see whether that has been successfully applied? It sometimes isnt.
on 23-05-2023 18:12
Hi there. Virgin sent out a new hub 5 to replace hub 3
on 26-05-2023 08:29
Thank you for your reply Doddsy19.
Can you please confirm which devices you are using to run the speed tests from?
Are all wireless devices impacted or does it depend on the room the device is in?
on 27-05-2023 06:02
Checking speed through mobile phone tablets and firestick
on 29-05-2023 10:54
