on 22-10-2021 07:41
Virgin is reporting no issues in my area and running their test shows no problems, but my internet as been too unstable to use for days. Outlook cannot connect, web browsing is intermittent, work is impossible. Yet again I am using my phone's hotspot.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/555a3cec7d9752a7ec2a51f5d84d6d2a2ea2bfac
on 22-10-2021 07:42
Time | Priority | Description |
22/10/2021 06:39:9 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 21:53:18 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 21:53:18 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 20:53:24 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 20:53:24 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 16:56:12 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 16:56:11 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 16:54:39 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 16:54:39 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 16:52:51 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 16:52:51 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 10:42:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 10:42:43 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 10:21:24 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 10:21:24 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 09:42:49 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 09:42:49 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 09:35:57 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 09:35:57 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 09:34:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 22-10-2021 07:42
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 25800000 | 42.8 | 5120 | 32 qam | 6 |
2 | 32600000 | 43.3 | 5120 | 32 qam | 5 |
3 | 39400000 | 43.3 | 5120 | 32 qam | 4 |
4 | 46200000 | 42.8 | 5120 | 32 qam | 3 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 3 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 22-10-2021 07:43
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 170750000 | 1.4 | 40 | 256 qam | 5 |
2 | 138750000 | 2 | 38 | 256 qam | 1 |
3 | 146750000 | 1.7 | 40 | 256 qam | 2 |
4 | 154750000 | 1.5 | 40 | 256 qam | 3 |
5 | 162750000 | 1.2 | 40 | 256 qam | 4 |
6 | 178750000 | 1 | 38 | 256 qam | 6 |
7 | 186750000 | 1 | 38 | 256 qam | 7 |
8 | 194750000 | 1 | 40 | 256 qam | 8 |
9 | 202750000 | 0.7 | 40 | 256 qam | 9 |
10 | 210750000 | 0.5 | 38 | 256 qam | 10 |
11 | 218750000 | 0.5 | 40 | 256 qam | 11 |
12 | 226750000 | 0.2 | 40 | 256 qam | 12 |
13 | 234750000 | 0.2 | 38 | 256 qam | 13 |
14 | 242750000 | 0 | 38 | 256 qam | 14 |
15 | 250750000 | 0 | 38 | 256 qam | 15 |
16 | 258750000 | 0 | 40 | 256 qam | 16 |
17 | 266750000 | 0 | 38 | 256 qam | 17 |
18 | 274750000 | -0.2 | 38 | 256 qam | 18 |
19 | 282750000 | 0 | 38 | 256 qam | 19 |
20 | 290750000 | 0 | 38 | 256 qam | 20 |
21 | 298750000 | 0.4 | 38 | 256 qam | 21 |
22 | 306750000 | 0.2 | 38 | 256 qam | 22 |
23 | 314750000 | 0 | 38 | 256 qam | 23 |
24 | 322750000 | 0 | 38 | 256 qam | 24 |
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 40.3 | 6 | 0 |
2 | Locked | 38.9 | 6 | 0 |
3 | Locked | 40.3 | 5 | 0 |
4 | Locked | 40.3 | 6 | 0 |
5 | Locked | 40.9 | 5 | 0 |
6 | Locked | 38.9 | 5 | 0 |
7 | Locked | 38.9 | 5 | 0 |
8 | Locked | 40.3 | 7 | 0 |
9 | Locked | 40.3 | 6 | 0 |
10 | Locked | 38.9 | 3 | 0 |
11 | Locked | 40.9 | 6 | 0 |
12 | Locked | 40.3 | 6 | 0 |
13 | Locked | 38.6 | 6 | 0 |
14 | Locked | 38.9 | 7 | 0 |
15 | Locked | 38.6 | 9 | 0 |
16 | Locked | 40.3 | 4 | 0 |
17 | Locked | 38.6 | 4 | 0 |
18 | Locked | 38.6 | 6 | 0 |
19 | Locked | 38.9 | 6 | 0 |
20 | Locked | 38.9 | 6 | 0 |
21 | Locked | 38.6 | 5 | 0 |
22 | Locked | 38.6 | 6 | 0 |
23 | Locked | 38.9 | 6 | 0 |
24 | Locked | 38.9 | 8 | 0 |
on 22-10-2021 15:08
Hi nikbower
Thanks for posting. My apologies for the broadband issues.
I've done a system check today and you're affected by an SNR (signal to noise ratio) issue. F009338025 is the fault reference number and the estimated fix date is the 2nd November.
Best,
on 22-10-2021 20:53
OMG what a nightmare. I have spent more time affected by SNR issues in my area over the past 2 years than I have been free of them. A fix date of 2 November means neither my wife nor I will be able to work effectively from home for the whole of next week. This really is unacceptable. Do you have any idea what is to blame, where the problem is and how to fix it, or is that fix date just going to keep moving further out every time we approach?
on 25-10-2021 12:51
I'm sorry for any inconvenience this is causing.
We will aim to have this resolved as soon as possible.
The only additional information I can see if that there are errors at the Node.
Alex_Rm
on 25-10-2021 18:29
Anything you can do to help would be appreciated, thank you
on 27-10-2021 18:50
Thank you for your response @nikbower
I have had a look into your account regarding this and I can confirm the SNR outage is still ongoing. The current estimated fix time now is 02 NOV 2021 14:00. Our team will aim to get this resolved as soon as possible.
If the issue persists after the given estimated fix time, please let us know and we will do our best to help from here.
03-11-2021 17:13 - edited 03-11-2021 17:20
Hi guys, it's 3 November and the issue is not fixed. Please check my BQM (live linked higher in the chain) to see what a catastrophic failure of service I am enduring right now. What are you able to do about this? When can it be fixed?
