04-08-2021 10:16 - edited 04-08-2021 10:19
Hi Folks
My M500 line has been unusable for the past week or two, it is down more than it is up and this would be the 3rd time that i have had this issue in the last few months with two engineer visits and one hub replacement not that long ago.
I had an engineer booked for today but it stabilized for a while so i cancelled the appointment, which was a terrible mistake as its back to its usual antics today. Graph below shows just how crap it has been:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e8ad6f49cd5bc876358357549991bac8bd460485-04-08-2021
Any resolution would be much welcome, and happy to share any further info or router logs if need be!
on 04-08-2021 11:14
@tokk1es wrote:Any resolution would be much welcome, and happy to share any further info or router logs if need be!
Yes please. Broadband isn't my speciality and others will be able to interpret them, but you can rarely have too much info in these cases..
Go-to to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) but don't log in. Click on "router status", and copy & paste the data from each of the tabs.
on 04-08-2021 22:17
Cheers mate - pasted below!
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 203000000 | -0.4 | 38 | 256 qam | 9 |
2 | 139000000 | -0.4 | 38 | 256 qam | 1 |
3 | 147000000 | 0 | 38 | 256 qam | 2 |
4 | 155000000 | -0.2 | 38 | 256 qam | 3 |
5 | 163000000 | -0.7 | 38 | 256 qam | 4 |
6 | 171000000 | -0.4 | 38 | 256 qam | 5 |
7 | 179000000 | 0.2 | 38 | 256 qam | 6 |
8 | 187000000 | 0.4 | 38 | 256 qam | 7 |
9 | 195000000 | 0 | 38 | 256 qam | 8 |
10 | 211000000 | 0 | 38 | 256 qam | 10 |
11 | 219000000 | 0.2 | 38 | 256 qam | 11 |
12 | 227000000 | 0 | 38 | 256 qam | 12 |
13 | 235000000 | -0.5 | 38 | 256 qam | 13 |
14 | 243000000 | -0.7 | 38 | 256 qam | 14 |
15 | 251000000 | -0.5 | 38 | 256 qam | 15 |
16 | 259000000 | -0.5 | 38 | 256 qam | 16 |
17 | 267000000 | -0.7 | 38 | 256 qam | 17 |
18 | 275000000 | -0.7 | 38 | 256 qam | 18 |
19 | 283000000 | -0.5 | 38 | 256 qam | 19 |
20 | 291000000 | -0.4 | 38 | 256 qam | 20 |
21 | 299000000 | -0.2 | 38 | 256 qam | 21 |
22 | 307000000 | 0 | 38 | 256 qam | 22 |
23 | 315000000 | 0.9 | 38 | 256 qam | 23 |
24 | 323000000 | 1.7 | 38 | 256 qam | 24 |
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 38.9 | 7 | 0 |
2 | Locked | 38.6 | 4 | 21 |
3 | Locked | 38.9 | 6 | 0 |
4 | Locked | 38.9 | 5 | 0 |
5 | Locked | 38.9 | 0 | 0 |
6 | Locked | 38.9 | 15 | 0 |
7 | Locked | 38.9 | 5 | 0 |
8 | Locked | 38.9 | 3 | 0 |
9 | Locked | 38.6 | 0 | 0 |
10 | Locked | 38.9 | 6 | 0 |
11 | Locked | 38.9 | 2 | 0 |
12 | Locked | 38.9 | 5 | 0 |
13 | Locked | 38.9 | 0 | 0 |
14 | Locked | 38.9 | 0 | 0 |
15 | Locked | 38.9 | 5 | 0 |
16 | Locked | 38.9 | 4 | 0 |
17 | Locked | 38.9 | 0 | 0 |
18 | Locked | 38.9 | 6 | 0 |
19 | Locked | 38.9 | 2 | 0 |
20 | Locked | 38.9 | 5 | 0 |
21 | Locked | 38.9 | 11 | 0 |
22 | Locked | 38.6 | 0 | 0 |
23 | Locked | 38.9 | 0 | 0 |
24 | Locked | 38.6 | 6 | 0 |
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 60300000 | 57 | 5120 | 64 qam | 1 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | ATDMA | 0 | 0 | 0 | 0 |
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;04/08/2021 08:38:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:01:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 20:31:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 13:41:6criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:01:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:11Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:7criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:6criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 10:26:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 09:41:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/08/2021 09:40:37criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VE
on 04-08-2021 22:41
You only have one upstream channel when there should be four and the level is far too high. First check if there are any faults in your area on
150 or 0800 561 0061
If none showing call customer services or wait a few days for a VM staff member to get to your post.
on 06-08-2021 13:26
Hi tokk1es,
Thanks for getting in touch, I'm sorry that you're having some problems with your broadband connection.
I'd be more than happy to look into this for you, I'll just need to confirm a few details with you via Private Message. Please look out for a purple envelope in the top right corner of your screen.
Kind regards,
Laurie
on 17-08-2021 13:29
The engineer did come out but said there was no issue - the issue is intermittent so murphy's law, it was not there when he came. It becomes apparent when there is bandwidth usage on the line, so when its idle / browsing its ok most of the time but anytime i download something it drops out for 5 to 10 minutes at a time.
Graph from today:
on 17-08-2021 13:34
on 19-08-2021 13:53
Thanks for getting back to us @tokk1es.
I'm sorry to hear this, I appreciate this must be frustrating and we apologise for any inconvenience caused.
Are you able to perform a pin hole reset as advised by @jbrennand and post the live link to the BQM once you've done so?
