on 16-05-2023 22:12
Hello, I have been experiencing intermitent internet for a couple of weeks now both on the WIFI and hard wired side of things. Here is a copy of my current network log. As you can see there are many unicast errors but also dynamic range window violations and commanded power exceeds values. Most of the time the light on the router stays solid white even when experiencing issues but sometimes changes to red. Do I need an engineer?
16-05-2023 21:50:15 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:50:15 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:50:15 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:50:15 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:50:15 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:50:01 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:50:01 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:50:01 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:50:01 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:50:01 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:49:44 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:49:43 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:49:43 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:49:17 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:48:55 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:48:55 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:48:52 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
16-05-2023 21:48:46 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:48:46 | warning | Dynamic Range Window violation |
16-05-2023 21:48:46 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-05-2023 21:48:46 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 16-05-2023 22:36
Please post a full set of stats.
on 17-05-2023 16:11
What stats do I need to post?
on 17-05-2023 17:13
See this....
____________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 17-05-2023 18:30
Thanks for the update, here is the info.
17-05-2023 18:28:44 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:28:44 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:28:44 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:28:24 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:28:24 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:28:24 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:27:24 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:27:24 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:27:24 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:27:04 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:27:04 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:26:24 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:26:04 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:26:04 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 18:23:45 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:24:02 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:24:02 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:16:31 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:16:31 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:12:32 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:12:29 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:12:29 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:12:19 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:12:19 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:11:52 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:06:52 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:06:52 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 17:04:12 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 16:42:20 | notice | CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: 680596; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 16:42:19 | warning | Unicast DSID PSN startup error |
17-05-2023 16:42:05 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2023 16:42:05 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
0 | 49600000 | 56.5 | 5120 | QAM 64 | 9 |
1 | 43100000 | 56 | 5120 | QAM 64 | 10 |
2 | 36600000 | 55.5 | 5120 | QAM 64 | 11 |
3 | 30100000 | 55.8 | 5120 | QAM 64 | 12 |
4 | 23600000 | 55 | 5120 | QAM 64 | 13 |
0 | ATDMA | 0 | 903 | 17 | 0 |
1 | ATDMA | 0 | 903 | 18 | 0 |
2 | ATDMA | 0 | 903 | 35 | 0 |
3 | ATDMA | 0 | 903 | 18 | 0 |
4 | ATDMA | 0 | 903 | 36 | 0 |
1 | 138000000 | -1.9 | 39 | QAM 256 | 1 |
2 | 146000000 | -2.2 | 39 | QAM 256 | 2 |
3 | 154000000 | -2.5 | 40 | QAM 256 | 3 |
4 | 162000000 | -2.5 | 41 | QAM 256 | 4 |
5 | 170000000 | -2.4 | 41 | QAM 256 | 5 |
6 | 178000000 | -2.4 | 41 | QAM 256 | 6 |
7 | 186000000 | -3 | 41 | QAM 256 | 7 |
8 | 194000000 | -3.3 | 41 | QAM 256 | 8 |
9 | 202000000 | -3.6 | 41 | QAM 256 | 9 |
10 | 210000000 | -3.2 | 41 | QAM 256 | 10 |
11 | 218000000 | -3 | 39 | QAM 256 | 11 |
12 | 226000000 | -3.2 | 39 | QAM 256 | 12 |
13 | 234000000 | -3.7 | 41 | QAM 256 | 13 |
14 | 242000000 | -3.9 | 41 | QAM 256 | 14 |
15 | 250000000 | -3.9 | 41 | QAM 256 | 15 |
16 | 258000000 | -3.8 | 41 | QAM 256 | 16 |
17 | 266000000 | -3.8 | 41 | QAM 256 | 17 |
18 | 274000000 | -3.9 | 41 | QAM 256 | 18 |
19 | 282000000 | -4.2 | 41 | QAM 256 | 19 |
20 | 290000000 | -4.2 | 41 | QAM 256 | 20 |
21 | 298000000 | -3.9 | 41 | QAM 256 | 21 |
22 | 306000000 | -3.8 | 41 | QAM 256 | 22 |
23 | 314000000 | -3.9 | 41 | QAM 256 | 23 |
24 | 322000000 | -4.6 | 40 | QAM 256 | 24 |
25 | 330000000 | -5 | 40 | QAM 256 | 25 |
26 | 338000000 | -5.2 | 40 | QAM 256 | 26 |
27 | 346000000 | -5 | 40 | QAM 256 | 27 |
28 | 354000000 | -4.8 | 40 | QAM 256 | 28 |
29 | 362000000 | -4.5 | 40 | QAM 256 | 29 |
30 | 370000000 | -4.8 | 40 | QAM 256 | 30 |
31 | 378000000 | -5.3 | 40 | QAM 256 | 31 |
1 | Locked | 39 | 43105260 | 5390 |
2 | Locked | 39 | 10038725 | 61567 |
3 | Locked | 40 | 423325 | 62982 |
4 | Locked | 41 | 1175334 | 81995 |
5 | Locked | 41 | 269952 | 349183 |
6 | Locked | 41 | 84383 | 165953 |
7 | Locked | 41 | 275688 | 504879 |
8 | Locked | 41 | 29221 | 4654 |
9 | Locked | 41 | 24572 | 4055 |
10 | Locked | 41 | 19206 | 2958 |
11 | Locked | 39 | 19577 | 3630 |
12 | Locked | 39 | 18929 | 2714 |
13 | Locked | 41 | 16395 | 1484 |
14 | Locked | 41 | 19467 | 2137 |
15 | Locked | 41 | 17928 | 1697 |
16 | Locked | 41 | 11985 | 979 |
17 | Locked | 41 | 15276 | 1307 |
18 | Locked | 41 | 13693 | 1109 |
19 | Locked | 41 | 17456 | 471 |
20 | Locked | 41 | 73077 | 464 |
21 | Locked | 41 | 72714 | 348 |
22 | Locked | 41 | 10985 | 82 |
23 | Locked | 41 | 5753 | 204 |
24 | Locked | 40 | 5912 | 247 |
25 | Locked | 40 | 3077 | 58 |
26 | Locked | 40 | 3284 | 87 |
27 | Locked | 40 | 4530 | 129 |
28 | Locked | 40 | 6130 | 17 |
29 | Locked | 40 | 1846195 | 17 |
30 | Locked | 40 | 3076277 | 23 |
31 | Locked | 40 | 20975457 | 124 |
on 17-05-2023 18:38
Not great... but can you start from a clean sheet and do this and then post up the stats again after 20-30 minutes
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing. When its light, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
on 17-05-2023 20:22
Cheers for the info, have done the reset and checked all cables. I'll just keep an eye on it now and get back with anything further.
on 19-05-2023 20:38
Thanks for the response stelyth,
Welcome back to the community.
Keep us updated on how things go.
Regards,
on 19-05-2023 22:34
I do have to say, I’m not too sure why you were asked to post up all sorts of additional data, when it was screamingly obvious from your first post that you have an upstream connectivity issue, could be a loose cable joint, but I doubt it, almost certainly you’ll need a tech visit to sort it out.
