on 11-05-2021 15:10
Recently we upgraded to the 4.0 Hub, but ever since then the Philips Hue bridge doesn't work. You plug it in and it only shows a power light, no connection to the network
I've tried different ethernet cables and ports on the hub, tried resetting the hub
I've checked the homepage of the hub and Philip Hue is not listed but other items plugged into the ethernet are listed
on 11-05-2021 15:15
You may have to split the SSID and turn off Smart Optimisation for the Hub's wifi.
on 11-05-2021 15:17
Sorry for the ignorance but this is the same if the hubs are connected via Ethernet cable?
on 11-05-2021 15:30
on 11-05-2021 15:35
on 12-05-2021 11:32
@gary_dexter wrote:
The Hue hub connects via Ethernet not Wifi - so I can't see it being an issue with the wifi settings.
Ahh, everyday is a school day 😊
on 13-05-2021 15:23
Hi @Awilkin1983,
Welcome back to our community forums.
Sorry to hear you are having issues with your Philips Hue in regards to your Hub 4. Were you able to resolve the issue using the great advice given by the community?
Please let us know how you got on.
on 13-05-2021 15:29
As stated on the community, Philips lightbulbs have their own hub which connects to the virgin hub via ethernet and so I'm unsure why this would be resolved by separating the wifi frequency.
But no, there's been no answer yet that might fix the issue sadly
on 13-05-2021 15:34
Thank you for letting us know @Awilkin1983.
Have you tried rebooting the Philips Hue to see if the issue persists?
on 13-05-2021 15:49
Rebooted and held down the reset button to try to reset it back to defaults
Only the power light shows
