on 05-03-2022 06:41
Morning all,
Twitter sent me here to the experts!
Since yesterday, I've not been able to connect to WiFi. The TV is connected, my husband's phone is connected, our Google home devices are all working. The only issue seems to be my phone. I have a full signal but am either seeing a "cannot authorise connection" or "connected without Internet" message.
I have hard reset the router, restarted my phone - both numerous times, I've forgotten the network and rejoined, the hub isn't new and my device hasn't had an update recently.... I'm lost. Any ideas?
on 05-03-2022 09:34
The mobile network signal on a phone has nothing to do with the WiFi connectivity for starters, but hey ho.
Can this same phone connect to other wireless routers, or is it only your home one that it has problems with? Is your phone an iOS or Android model?
on 05-03-2022 11:21
I meant the WiFi signal is strong, not my mobile signal.
I have an android phone and can connect to other networks.
on 07-03-2022 11:56
Hi Julit14
What is the make and model of your handset
Gareth_L
on 07-03-2022 14:12
on 09-03-2022 14:24
Thanks for coming back to us with your update @Julit14, how is it going at the moment, any further issues since you last posted?
Regards,
Steven_L
on 09-03-2022 19:44
Hi Steven,
It's been a bit patchy but I'm pretty convinced it's my phone that's the issue.
Thanks for the help within the forum.
Jules
on 12-03-2022 10:21
Hi @Julit14
Thanks for the reply!
Do you not experience the issues on any other devices at all?
