  • 8
Message 1 of 9
Un-reliable connection - SYNC Timing Synchronization failures
For the past couple of weeks we've been experiencing regular drops in connection - pauses while watching streaming TV, disconnects from video calls, VPN connections etc.  Speedtests are fluctuating wildly.
I'm seeing lots of errors in the network logs, here's my info from this morning.  I rebooted the hub roughly 24 hours before this:
Cable Modem Status
Item
Status
Comments
323000000
Locked
Ranged Upstream Channel (Hz)
53699909
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
323000000
2.5
38
256 qam
24
2
139000000
-0.2
37
256 qam
1
3
147000000
-0.5
37
256 qam
2
4
155000000
-0.2
37
256 qam
3
5
163000000
0
38
256 qam
4
6
171000000
0.2
38
256 qam
5
7
179000000
0.2
38
256 qam
6
8
187000000
0.2
38
256 qam
7
9
195000000
0.2
38
256 qam
8
10
203000000
0.4
38
256 qam
9
11
211000000
0.5
38
256 qam
10
12
219000000
0.5
38
256 qam
11
13
227000000
0.2
38
256 qam
12
14
235000000
0
38
256 qam
13
15
243000000
-0.5
38
256 qam
14
16
251000000
-0.2
38
256 qam
15
17
259000000
0
38
256 qam
16
18
267000000
0.5
38
256 qam
17
19
275000000
0.7
38
256 qam
18
20
283000000
0.9
38
256 qam
19
21
291000000
1.2
38
256 qam
20
22
299000000
1.7
38
256 qam
21
23
307000000
2
38
256 qam
22
24
315000000
2.4
40
256 qam
23
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
1942479
1337328
2
Locked
37.6
5599973
4216171
3
Locked
37.6
5329292
3934032
4
Locked
37.3
5051173
3713771
5
Locked
38.6
4791071
3486719
6
Locked
38.6
4526622
3258277
7
Locked
38.6
4324950
3063980
8
Locked
38.6
4106779
2872818
9
Locked
38.6
3908660
2715004
10
Locked
38.6
3710157
2550242
11
Locked
38.6
3558012
2445415
12
Locked
38.6
3375432
2298166
13
Locked
38.6
3229499
2176898
14
Locked
38.6
3081881
2082524
15
Locked
38.6
2934317
1984551
16
Locked
38.6
2816727
1908707
17
Locked
38.9
2693366
1809142
18
Locked
38.9
2570366
1734866
19
Locked
38.6
2460735
1663918
20
Locked
38.9
2359552
1601762
21
Locked
38.9
2273010
1547417
22
Locked
38.6
2201326
1482295
23
Locked
38.9
2095452
1449383
24
Locked
40.3
2011437
1411247
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53699909
4.6
5120
64 qam
2
2
39400000
3.675
5120
64 qam
4
3
46200000
4.575
5120
64 qam
3
4
60299995
3.775
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
SFID
5276
Max Traffic Rate
230000061
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
5275
Max Traffic Rate
22000061
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
logs continued in next post...
  • 8
Message 2 of 9
Re: Un-reliable connection - SYNC Timing Synchronization failures
Time
Priority
Description
21/10/2020 07:56:8
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 07:56:7
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 07:55:12
Warning!
21/10/2020 07:55:10
critical
21/10/2020 07:46:50
Warning!
21/10/2020 07:46:48
critical
21/10/2020 07:46:36
Warning!
21/10/2020 07:46:36
critical
21/10/2020 07:46:31
Warning!
21/10/2020 07:46:30
critical
21/10/2020 07:46:27
Warning!
21/10/2020 07:46:23
critical
21/10/2020 07:46:18
Warning!
21/10/2020 07:46:15
critical
21/10/2020 07:46:9
Warning!
21/10/2020 07:46:8
critical
21/10/2020 07:38:51
Warning!
21/10/2020 07:38:51
critical
21/10/2020 07:35:21
Warning!
21/10/2020 07:35:20
critical
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/581307eb6567f71a37bea0bab62457fac9179506]My Broadband Ping[/url]
  • 8
Message 3 of 9
I think I should also point out, I am using SuperHub 3.0 in standard mode.
The problem is affecting wired and wireless connections.
  • 24.77K
  • 1.43K
  • 3.15K
Message 4 of 9
Looking at those stats and BQM, unless there’s an area issue you’ll need an engineer.
When was the hub last rebooted?
  • 8
Message 5 of 9
Hub was rebooted around 24 hours before those stats
  • 11.9K
  • 927
  • 1.53K
Message 6 of 9
Your >> Live BQM << is a mess.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
Mike Robinson
  • 8
Message 7 of 9
No issues reported in Service Status or on the phone. Checked all internal cables, no obvious problems.
  • 11.9K
  • 927
  • 1.53K
Message 8 of 9
Call in for an engineer visit, don't be technical; just tell them that your internet keeps cutting out.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
  • 8
Message 9 of 9
Finally fixed(?), but not an easy route and shocking customer support from VM:
The online diagnostic tool detected an 'intermittent' issue and applied 'some change'.  Check back after 24 hours.
24 hours later, no improvement, but the diagnostic tool allows me to book an engineer.  Booked for 3 days time 🙂
Engineer arrives, says the signal is too high.  Takes 2x attenuators off the input cable and replaces with a different one and installs a new SH3.  All seems good for a few hours, then back to the same issues.
The online detector tool encounters errors while trying to run and doesn't complete, so can't confirm if faults found or allow me to book another engineer.
Out of desperation I call and wait for a couple of hours to speak to someone.  Support person (off-shore) makes a setting change their end and says it will be fixed.  I ask for an engineer visit just in case (that I can cancel if the problem is really fixed), but they say they can't do that unless there is fault found, which at this time there isn't.  He said the best they could do for now was make an appointment to call me back the next day to see how it was going.
The next day, issue is still present.  Appointment time for call came and went - no phone call.   I call and wait another 90mins or so before getting through to someone (again off-shore).  He tells me that there is no policy for calling customers back - meaning that one of these two is a liar.  He then proceeds to get me to change a Wi-Fi setting in the hub.  I explain the issues I am having and it's affected wired connections, so isn't a wireless issue, but he arrogantly tells me that he does this thing all the time and knows what he's doing and it will definitely fix my issue.  I started pushing back, insisting on arranging an engineer booking, at which time he simply says thank you for calling and hung up.  I have lodged a formal complaint against this guy, but unsurprisingly I've not heard anything back on that either.
Guess what - he didn't solve my issue either.   I made another call to support (earlier in the morning, but still an hour wait) and got through to someone in the UK.  No questions, no problems, he simply arranged the engineer visit.
Engineer #2 arrives and listens to the issues.  Confirms signal is too high, but goes to the cabinet to check.  Changes slots to a lower power one (tells me there's only 2 options in that cabinet) He replaced the connectors at the same time.  He also changed all the external connectors outside the house, meaning apart from the under ground cable, everything connection from the cabinet to the hub is new.
BQM monitor has been clear for 2 days now.  Speeds are good but not stunning, but I'll settle for stability for the time being.  PreRS Errors are all below 40 and PostRS are all at zero too.  The sync error messages have also gone.
Although it seems to be working, I'm seriously un-impressed with VM customer service here, to the point where I was investigating alternative suppliers and was very close to switching away. I may still do so, but we'll see how it goes.
