STDalley
Message 1 of 9
Two WiFi signals from one hub
I have been having a problem recently with my WiFi, which doesn't affect my usage whatsoever, but it is very strange and I'd like to know why it's happening. I have my WiFi off all the time and only switch it on every now and then. Recently, when I switch it on, I get two signals come up instead of one. One of them is named under my customised name and the other says Virgin Media. The Virgin Media one asks for a username and password to access it. I know, without a doubt that this is coming from my hub as it appears exactly when I switch my WiFi on and disappears exactly when I switch it off. Is it possible that my hub has been turned into a hotspot? I tried to speak to someone at Virgin's customer service department and they couldn't understand what I was trying to say, tried to infer that someone was magically switching their WiFi on and off at the same time as me and that neither they nor ANYONE at Virgin could check if it was a hotspot. Can anyone help please?
  • 136
  • 53
HavencroftKev
Superfast
Message 2 of 9
Re: Two WiFi signals from one hub
The Hub 2 will send out two signals one in 2g and one 5g. The 5g signal is faster and better to use at close range (provided your device is able to access it) and the 2g is slower and better to use for longer distances from the hub.
Imagine the 5g is Usain Bolt, fast but only runs a short distance.
The 2g is a long distance runner, slower but can go further.
  • 9.37K
  • 362
  • 2.31K
Message 3 of 9
Yes, your firmware has the VM wifi hot spot turned on:
http://community.virginmedia.com/t5/forums/searchpage/tab/message?q=virgin+wifi+hotspot
You can turn it off from a setting on your myvirginmedia page.
  • 9.78K
  • 855
  • 2.06K
Message 4 of 9
Yep, it looks like the new VM Hotspot that has just been rolled out on the Hub3s.
  • 9.37K
  • 362
  • 2.31K
Message 5 of 9
Just beat you to it by a millisecond. Smiley Tongue
  • 9.78K
  • 855
  • 2.06K
Message 6 of 9
Curse that speedtyping course  Smiley Very Happy
STDalley
Message 7 of 9
Thank you, it's concerning that Virgin customer services were clueless about this.
  • 9.37K
  • 362
  • 2.31K
Message 8 of 9
It's not the first thing they've been clueless about. It's been in the offing for a couple of years now.
  • 9.37K
  • 362
  • 2.31K
Message 9 of 9
Here's the original news article from July 2015:
http://www.ispreview.co.uk/index.php/2015/07/isp-virgin-media-turns-superhub-routers-into-uk-public-...
It's been on-again-off-again with firmware getting reverted a couple of times, so no guarantee how long this time will last. First time on the Hub 3 though.
