  • 15
londonpb
Message 1 of 16
Total packet loss, latency issues, netflix buffering
Dear Community, my first message...
Very recently signed up to Virgin (circa 17 Nov) and have noticed Netflix buffering at 25% and then being kicked out of the internet conncection. Happens on my youview box and smart tv. Several times during one show.
Then checked connection via thinkbroadband and noticed high latency and total packet loss.
Connection to TV/you view is via Ethernet over powerline (brand new), 1300Mbps device.
I am on SH3 with latest firmware.
Have also observed wifi connection problems on laptop, particularly via VPN.
Any tips?
Photos below of BQM test results.
Note - speed tests all fine.
  • 11.66K
  • 774
  • 3.42K
Message 2 of 16
Re: Total packet loss, latency issues, netflix buffering
Can you post your upstream and downstream power levels..
Go to 192.168.0.1
Do NOT LOG IN- Click router status
And post Downstream and Upstream levels..
  • 15
londonpb
Message 3 of 16
thank you for the reply - will do later when I get home from work.
  • 15
londonpb
Message 4 of 16
Ok,
so here is my downstream data (this website has messed with the format slightly)
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1298750000038256 qam17
2322750000-0.538256 qam20
3314750000-0.438256 qam19
4306750000-0.438256 qam18
5290750000-0.238256 qam16
6282750000-0.240256 qam15
7274750000-0.538256 qam14
8266750000-0.538256 qam13
9258750000-0.539256 qam12
10250750000-0.540256 qam11
11242750000-0.238256 qam10
12234750000-0.238256 qam9
13226750000038256 qam8
14218750000040256 qam7
15210750000038256 qam6
162027500000.440256 qam5
171947500000.440256 qam4
181867500000.540256 qam3
191787500000.440256 qam2
201707500000.440256 qam1
1Locked38.970
2Locked38.900
3Locked38.9230
4Locked38.9410
5Locked38.960
6Locked40.3220
7Locked38.93510
8Locked38.9100
9Locked39.81230
10Locked40.3630
11Locked38.960
12Locked38.9620
13Locked38.970
14Locked40.380
15Locked38.91510
16Locked40.360
17Locked40.3130
18Locked40.380
19Locked40.980
20Locked40.320
And here is my upstream data...
is anything afoot?
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
14620000044.5512064 qam87
25370000044.8512064 qam86
36030000045512064 qam85
43940000044.5512064 qam88
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0030
2ATDMA0070
3ATDMA00100
4ATDMA0070
  • 11.66K
  • 774
  • 3.42K
Message 5 of 16
Looks okay, can you set up an alternative to BQM?
https://f8lure.mouselike.org/auth.asp
The big red blocks are likely a known issue with HUB3 and routing to BQM's Firebrick, F8Lure will give us a different take on it or confirm the packet loss.
  • 15
londonpb
Message 6 of 16
Ok thank you. I am trying this and when there's some data I will post on here, probably tomorrow. Appreciate your help!
  • 15
londonpb
Message 7 of 16
Ok, so far so good.
I only upgraded my powerline adaptors yesterday so perhaps this is what was causing buffering issues? I have not had an issue on netflix since...but I haven't watched more than 30 mins.
I don't know if this is a good graph or not mind you?
  • 11.66K
  • 774
  • 3.42K
Message 8 of 16
@londonpb wrote:
Ok, so far so good.
Nah although your real world experience is improved, that graph is still a bit pants. Guessing an area fault but Ill ask staff to take a look...
  • 15
londonpb
Message 9 of 16
Ok good to know I wasn’t losing my mind.
here’s an update, and there a spots of total packet loss.
  • 14.59K
  • 432
  • 46
Moderator (Retired) Ralph_R
Moderator (Retired)
Message 10 of 16
Thanks for the flag kippies, I've run a few checks on the connection here and looks there is a problem with High FEC count on the upstream side of things.
I've reported this with networks who should get on the case.
If you drop us an update in a day or two we'll gladly take a look at how things are progressing.
Cheers
Ralph_R
Forum Moderator
