on 15-08-2022 19:49
My hub is seriously hot, i have active Air con in the same room as the hub and temperature in that room is 19c
The hub is too hot to hold your hand on the top of, i have put two little things that raise it up so air can get in from underneath
you could easily boil an egg on the top of this thing, i am having to turn it off from around 9pm until 10am just to try and keep it cool
There is no way this hub temp is normal, it must be a design fault, is there anything i can do to keep it cooler?
I don't want to use this anymore to be honest, i don't think it is very safe, why do ISP companies give customers such garbage routers?
on 15-08-2022 20:49
HI danbottomburp, thanks for the message. I am sorry to hear that you are having issues with the router, I will send you a private message so that this can be looked into further. ^Chris.
