on 20-07-2021 17:51
I upgraded to the 1Gb broadband and the Hub 4.0... went well for a while, then it started dropping out, killing my vpn as well as giving truly terrible bandwidth.
The laptop is direct connected by Cat6 cable to the hub so the dropouts weren't due to WiFi, the WiFi however has become appallingly slow
Virgin engineers have been out, replaced all of the connectors, replaced the Hub 4.0 and even moved me to a different port in the relay box outside ... still the same
Tried to fix the WiFi by trying to set to manual rather than dynamic but was still atrocious as can be seen below .. has anyone else seen this issue?
on 23-07-2021 14:19
3.0 Downstream channels
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 411000000 | 4.199997 | 37.636276 | QAM256 | 1 |
2 | 419000000 | 4.400002 | 38.605377 | QAM256 | 2 |
3 | 427000000 | 5.000000 | 38.605377 | QAM256 | 3 |
4 | 435000000 | 4.800003 | 38.605377 | QAM256 | 4 |
5 | 443000000 | 4.699997 | 38.605377 | QAM256 | 5 |
6 | 451000000 | 4.599998 | 38.605377 | QAM256 | 6 |
7 | 459000000 | 5.099998 | 38.983261 | QAM256 | 7 |
8 | 467000000 | 5.400002 | 38.983261 | QAM256 | 8 |
9 | 475000000 | 5.199997 | 38.605377 | QAM256 | 9 |
10 | 483000000 | 5.199997 | 38.605377 | QAM256 | 10 |
11 | 491000000 | 5.300003 | 38.605377 | QAM256 | 11 |
12 | 499000000 | 5.300003 | 38.983261 | QAM256 | 12 |
13 | 507000000 | 5.400002 | 38.605377 | QAM256 | 13 |
14 | 515000000 | 5.099998 | 38.605377 | QAM256 | 14 |
15 | 523000000 | 4.599998 | 38.983261 | QAM256 | 15 |
16 | 531000000 | 4.800003 | 38.983261 | QAM256 | 16 |
17 | 539000000 | 4.800003 | 38.983261 | QAM256 | 17 |
18 | 547000000 | 5.300003 | 38.983261 | QAM256 | 18 |
19 | 555000000 | 5.400002 | 38.605377 | QAM256 | 19 |
20 | 563000000 | 5.300003 | 38.983261 | QAM256 | 20 |
21 | 571000000 | 5.199997 | 38.605377 | QAM256 | 21 |
22 | 579000000 | 5.099998 | 38.605377 | QAM256 | 22 |
23 | 587000000 | 5.099998 | 38.983261 | QAM256 | 23 |
24 | 595000000 | 4.699997 | 38.605377 | QAM256 | 24 |
25 | 603000000 | 4.599998 | 38.605377 | QAM256 | 25 |
26 | 611000000 | 4.099998 | 37.636276 | QAM256 | 26 |
27 | 619000000 | 4.199997 | 37.636276 | QAM256 | 27 |
28 | 627000000 | 4.199997 | 37.636276 | QAM256 | 28 |
29 | 635000000 | 3.700001 | 37.355988 | QAM256 | 29 |
30 | 643000000 | 3.599998 | 37.355988 | QAM256 | 30 |
31 | 651000000 | 3.700001 | 37.355988 | QAM256 | 31 |
Channel | Lock Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 37.636276 | 0 | 0 |
2 | Locked | 38.605377 | 0 | 0 |
3 | Locked | 38.605377 | 0 | 0 |
4 | Locked | 38.605377 | 0 | 0 |
5 | Locked | 38.605377 | 0 | 0 |
6 | Locked | 38.605377 | 0 | 0 |
7 | Locked | 38.983261 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.605377 | 0 | 0 |
10 | Locked | 38.605377 | 0 | 0 |
11 | Locked | 38.605377 | 0 | 0 |
12 | Locked | 38.983261 | 0 | 0 |
13 | Locked | 38.605377 | 0 | 0 |
14 | Locked | 38.605377 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.605377 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 38.605377 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.605377 | 0 | 0 |
25 | Locked | 38.605377 | 0 | 0 |
26 | Locked | 37.636276 | 0 | 0 |
27 | Locked | 37.636276 | 0 | 0 |
28 | Locked | 37.636276 | 0 | 0 |
29 | Locked | 37.355988 | 0 | 0 |
30 | Locked | 37.355988 | 0 | 0 |
31 | Locked | 37.355988 | 0 | 0 |
3.1 Downstream channels
Channel | Channel Width (MHz) | FFT Type | Number of Active Subcarriers | Modulation (Active Profile) | First Active Subcarrier (Hz) |
41 | 96 | 4K | 1880 | QAM4096 | 728 |
Channel ID | Lock Status | RxMER Data (dB) | PLC Power (dBmV) | Correcteds (Active Profile) | Uncorrectables (Active Profile) |
41 | Locked | 36 | -1.2 | 182815911 | 660 |
