on 28-12-2021 10:04
Hello all,
Following the install of my services mid 2021 I have been seeing high (but somewhat fluctating) SNR and power levels on my Super Hub 4. They used to sit around 5/6db and around 39/40 on SNR.
A couple of months ago we had a total outage and when the services went back online the power dropped to around 0/1db and the SNR around 34. However, it was now showing a 3.1 channel as being online.
Ever since the SNR has been dropping and recently it's showing 30 on a couple channels with loads of pre-rs errors and a couple "uncorrectables" on the 3.1 channel.
I'm assuming this will need an engineer visit? I've reset the router, rebooted about a hundred times and all connections from the drive to router are tight and clean.
Thanks in advance for any assistance, I'll try post stats on the following posts.
Answered! Go to Answer
on 30-12-2021 00:37
Hub just restarted on its own and the SNR is now 40 on all channels.
I assume VM did something so massive thanks to anyone involved!
on 28-12-2021 10:04
on 28-12-2021 10:05
on 28-12-2021 10:05
on 28-12-2021 10:05
on 30-12-2021 00:37
