Jojo101
Message 1 of 7
Telly Tablet not connecting
My telly tablet won’t connect to WiFi. It keeps stating authentification problem with the WiFi. However, the router is working fine as other devices are connected.
I’ve rebooted several times forgotten the WiFi info without luck.
Otherwise the tablet is working fine.
At a loss as to how to remedy.
Any suggestions?
  • 9.43K
  • 978
  • 1.48K
Message 2 of 7
Re: Telly Tablet not connecting
What Hub model do you have?  Is the Tablet a 2.4GHz network only device?  If so, is that network "switched off" in the Hub ?  If not, do other devices connect ok on the 2.4 network?
Jojo101
Message 3 of 7
I’ve checked on the bottom of the hub. It says it’s Hub 3.0. I’m not sure about the other info you e asked about? How do I check?
Thanks for replying.
Jojo101
Message 4 of 7
The tablet used to connect. But it hasn’t recently. I’m not aware of any changes.
  • 9.43K
  • 978
  • 1.48K
Message 5 of 7
The TT does have 5GHz connectivity it will also have a "factory reset" option - like the pinhole reset on the Hub - might be worth doing unless you have a lot of things stored on there - they will be wiped to the state it was in when you first got it.
Jojo101
Message 6 of 7
Have had to reset tablet, but thanks, not sure why I never thought of that.
Working now. Thanks. 👍
  • 10.32K
  • 281
  • 591
Forum Team (Retired) Emma_E
Message 7 of 7
Hi Jojo101,
Thanks for keeping us updated it sounds like you are all up and running now.
If you need any help in the future the team here and our lovely forum users will always be happy to take a look for you.
All the best
Emma
