on 13-12-2022 15:15
Hi, I am a broadband only customer and had my broadband installed yesterday. The engineer cut and replaced the TV aerial cable and also covered up the socket. I didn't find out until well into the evening otherwise I'd have asked him not to. I called customer services this morning and was told that someone would contact me AT SOME POINT but the team is really busy. Please can someone fix this? It shouldn't have happened in the first place and I don't want to be waiting for weeks without TV access.
on 13-12-2022 15:37
on 13-12-2022 15:41
I had a satellite cable and an aerial cable there. I agreed with the technician he could use the existing satellite cable as I don't use it. But I do use my TV aerial cable, which was also obvious as I had the TV cable connected to the wall TV plug.
on 13-12-2022 15:52
We're sorry to see the aerial cable has been removed and you can no longer make us of it, Luleta91.
Could you please kindly confirm whether you'd need this fitted back on and if you can use the TV services as normal without it or not?
Happy to assist further, so please tell us more.
on 13-12-2022 15:55
Thank you for quick reply. I need this fitted back as I can't watch TV at the moment
on 13-12-2022 16:02
Hey Luleta91, thanks for clarifying.
I will be able to check this further for you and help, I will send you a private message to do this shortly.
Please check the top-right corner of our forum and you should see a purple envelope. Click this and you'll see my message.
