on 09-09-2022 07:22
I switch off the tv every night using the remote control and every morning the box has turned itself off and i have no wifi until i turn the tv back on
on 11-09-2022 12:34
Hi raemar01,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
I'm sorry to hear that your TV box and WiFi is switching off each night.
When you say everything is off, do you mean to say that there is no power going to the TV box or Hub? If so then this would suggest an issue with the electricity itself as opposed to the boxes.
Do you have the Hub and TV box plugged in to the main sockets or an extension lead? Are they connected to a timer in anyway?
Pop back and let us know.
on 11-09-2022 14:04
on 11-09-2022 14:11
on 11-09-2022 14:19
Possibly ! If so would this disconnect my wifi, as that's what's happening
on 11-09-2022 14:34
on 13-09-2022 14:41
Hi @raemar01,
I can see that one of our community members @Sephiroth has offered some advice on this. Let us know if this has helped or if you need some further assistance today.
on 13-09-2022 19:44
Hi. My tv box must automatically go on standby, on further investigation have realised that the loss of wi fi is upstairs only when i go into the living room beside the hub i do have wifi so it's more to do with a really weak connection in the upper part of my house. Thanks for your help
on 13-09-2022 19:49
Yes it did help but my problem is still not resolved, i think I'll need to consider boosters or pods
on 13-09-2022 19:50
