on 12-08-2021 18:14
My Machine is wired up to the Hub 3.0 router. prior to changing ISP i had no issues with TEAMs or Zoom dropping calls
please confrim the Fix, if none are identified i will be forced to change provider
on 14-08-2021 08:37
Logically, switching between router and modem mode won't make any difference other than the (perhaps temporary) benefit of a restart and re-registration of the hub, since if there are any latency problems on the VM network these will be between the cable modem to CMTS. I'd restate my view that on the figures originally posted by @umar328 there's too many T3 timeouts across all upstream channels, which should not be there, based on the implied run-time from the pre-RS levels on the downstream.
We don't know if there is a VM latency problem yet, so something else for you (umar328) to try is to setup a Broadband Quality Monitor. That will show if anything is going on with your VM connection. Post a LINK to a LIVE, SHARED graph here and we'll see what's happening, don't post screenshots or a link to your logged in view of Thinkbroadband. Usually needs to run for 24 hours before we can draw reasonable conclusions, but the live graph will continuously update so you can post the link immediately.
Umar328 - sorry if this all sounds a bit techno-babble, bear with us, setup the BQM, usually these sorts of problems can be resolved. The other (main) possibility is that there is a latency problem due to any work VPN routing, but that would not normally affect Zoom calls if that's the "public" service.
on 16-08-2021 14:01
HI All, just keeping you informed that i will run the Broadband Quality Monitor on a day where i need to take several Zoom and Teams meetings throughout the day
i'll post the results as soon as they become availble this week
kind regards
Umar
on 18-08-2021 14:33
Hi @umar328,
Thank you for updating us and setting up a BQM, this will enable us to see a clearer picture of what is happening when you take Zoom calls / Teams meetings.
Kind regards,
Serena
on 18-08-2021 18:49
Hi i will continue to run to monitoring tool as ive only had a few TEAMs and Zoom calls, which continually drop durring meetings
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7acaa5f95dc21100a84a48778d5c4ae09b...
https://www.thinkbroadband.com/broadband/monitoring/quality/share/546be5074211966a5082126335339b9b66...
kind regards
umar
on 19-08-2021 10:19
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3f7a117a9255032547bab5274059cb96ccf19bd8-19-08-2021
on 19-08-2021 16:24
today ive experienced several drops in TEAMS meeting and the internet has been extremly slow throughout today
on 22-08-2021 09:53
Hi @umar328,
Thank you for coming back to us about your connection issue.
I cannot see any dropped packets on the BQM charts that you previously attached. I did have another look at your account however, and I can see that your Hub has the current uptime of 155 days.
Would you be able to reboot your Hub to see if this can help resolve your connection issue?
Please give this a try and let us know how you're getting on.
Thanks! 🙂
on 26-08-2021 10:43
i have rebooted the Hub, even before posting on this site and there hasnt been any changes regarding my experience using TEAMS and Zoom
the issue is persitant across a number of Virgin users when searching the this site
there is obviously a configuration issue here and its most likely from Virgin as ive never experieced this issue previously
what is the next course of troubleshooting ?
Kind regards
umar
on 26-08-2021 11:40
ive rebooted today and now the internet keeps dropping out
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7279ad36f94f64f59c2d6c138a6a909a46...
on 28-08-2021 13:15
Thanks for your post and welcome to the Community Forums, umar328,
Sorry to hear that you have been having connection issues. How has things been since your post? Is it happening on other devices?
I have run a remote diagnostic and have not been able to identify any issues with your connection.
We can also provide online broadband help here: https://www.virginmedia.com/help/services-support/broadband
Let us know if you need any further help.
Cheers,
Corey C
