on 24-09-2021 16:31
Hi all,
Or the past 5-7 days I've had my connection knocked offline multiple times per day, more frequently in the afternoon but has happened on many assorted hours of the day. Can't connect or even interface with the router over LAN unless I unplug and replug the router.
Have tried removing all powerline/LAN additions, setting static IP addresses to power-hungry devices and removing them altogether, factory resetting the router and all without any luck. Using the diagnostic tool and calling the the diagnostic line, there are apparently no faults in my area. I heavily rely on this connection as I work from home. Please help urgently. Problems started around 14th Sept.
Answered! Go to Answer
on 24-09-2021 20:37
Hi @lethaltoast thanks for posting and welcome back to our community.
I am sorry to hear that you're experiencing frequent drop-outs. I have located your account from here and I would like to send out a technician. I am going to send you a private message.
Lee_R
on 24-09-2021 20:55
Hi @lethaltoast thanks for confirming your details with me.
I have booked the first available technician appointment to attend your property. If you sign into your online account here, you can view and amend it.
Lee_R
on 24-09-2021 20:56
Thanks, I will have a look and update this thread accordingly.
on 28-09-2021 16:39
Hi all,
Engineer visited yesterday AM, replaced coax & I think he even mentioned some cabling outside was replaced. Mentioned something about signal blocking being too high.
Nevertheless, I'm still experiencing drops yesterday and today. Disappointing.
on 29-09-2021 19:56
@jnbrennand @Lee_R are tou able to advise next steps, please?
I've now been dealing with this issue for over 2 weeks.
on 01-10-2021 20:08
Hi Leathaltoast,
thanks for getting back to us, did the tech advise it needed more work doing to it and if so is there an eta?
Zoie
on 01-10-2021 20:12
Engineer did not advise any further work was needed. Said he had identified that the signal blocking was too high, replaced coax cable inside and another cable outside and problems are still persisting at least twice per day.
on 04-10-2021 11:42
Hi lethaltoast,
Thanks for the update, I'm sorry to hear you're still having some problems even after the engineer visit.
I've had a look and your downstream power levels are still slightly out of spec - so we may need to arrange a second engineer visit.
Just before we do, can you please ensure that all the cables are still tight at the back of the hub and try performing a factory reset? It's possible that the engineer may have fiddled with the cables during the visit and they are a bit loose.
Beth
on 05-10-2021 12:19
Have dome these necessary checks, problems still persist.
Thanks.
on 06-10-2021 21:26
Please update this support request, it's becoming a little ridiculous now.
