on 24-09-2021 16:31
Hi all,
Or the past 5-7 days I've had my connection knocked offline multiple times per day, more frequently in the afternoon but has happened on many assorted hours of the day. Can't connect or even interface with the router over LAN unless I unplug and replug the router.
Have tried removing all powerline/LAN additions, setting static IP addresses to power-hungry devices and removing them altogether, factory resetting the router and all without any luck. Using the diagnostic tool and calling the the diagnostic line, there are apparently no faults in my area. I heavily rely on this connection as I work from home. Please help urgently. Problems started around 14th Sept.
Answered! Go to Answer
on 15-10-2021 18:00
UPDATE:
Engineer checked the exchange as per my suggestion from a couple of weeks ago. Apparently it turns out my connection was extremely loose and could almost fall out just with a light touch.
It's a shame that the exchange cabinet wasn't checked earlier, but for the time being no issues since engineer visit and under replicable stress tests.
Will monitor for the next 2 days.
on 24-09-2021 16:33
Router Status
Cable Modem Status | ||
Item | Status | Comments |
Acquired Downstream Channel (Hz) | 203000000 | Locked |
Ranged Upstream Channel (Hz) | 53700000 | Locked |
Provisioning State | Online |
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 203000000 | 2.5 | 38 | 256 qam | 9 |
2 | 211000000 | 2.2 | 38 | 256 qam | 10 |
3 | 219000000 | 2.5 | 38 | 256 qam | 11 |
4 | 227000000 | 2.4 | 38 | 256 qam | 12 |
5 | 235000000 | 1.7 | 38 | 256 qam | 13 |
6 | 243000000 | 1.4 | 38 | 256 qam | 14 |
7 | 251000000 | 1.4 | 40 | 256 qam | 15 |
8 | 259000000 | 1.5 | 40 | 256 qam | 16 |
9 | 267000000 | 1 | 40 | 256 qam | 17 |
10 | 275000000 | 1 | 38 | 256 qam | 18 |
11 | 283000000 | 0.9 | 38 | 256 qam | 19 |
12 | 291000000 | 0.5 | 38 | 256 qam | 20 |
13 | 299000000 | 0 | 38 | 256 qam | 21 |
14 | 307000000 | 0.2 | 38 | 256 qam | 22 |
15 | 315000000 | 0.7 | 38 | 256 qam | 23 |
16 | 323000000 | 0.7 | 38 | 256 qam | 24 |
17 | 331000000 | 0.7 | 38 | 256 qam | 25 |
18 | 339000000 | 0.9 | 40 | 256 qam | 26 |
19 | 347000000 | 0.9 | 38 | 256 qam | 27 |
20 | 355000000 | 0.4 | 40 | 256 qam | 28 |
21 | 363000000 | 0.2 | 40 | 256 qam | 29 |
22 | 371000000 | 0.2 | 40 | 256 qam | 30 |
23 | 379000000 | 0.4 | 38 | 256 qam | 31 |
24 | 387000000 | 0.2 | 38 | 256 qam | 32 |
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 38.9 | 5 | 0 |
2 | Locked | 38.6 | 5 | 0 |
3 | Locked | 38.9 | 0 | 0 |
4 | Locked | 38.9 | 3 | 0 |
5 | Locked | 38.9 | 0 | 0 |
6 | Locked | 38.6 | 0 | 0 |
7 | Locked | 40.9 | 0 | 0 |
8 | Locked | 40.3 | 4 | 0 |
9 | Locked | 40.3 | 0 | 0 |
10 | Locked | 38.9 | 0 | 0 |
11 | Locked | 38.9 | 4 | 0 |
12 | Locked | 38.9 | 5 | 0 |
13 | Locked | 38.9 | 0 | 0 |
14 | Locked | 38.9 | 6 | 0 |
15 | Locked | 38.9 | 5 | 0 |
16 | Locked | 38.9 | 5 | 0 |
17 | Locked | 38.9 | 0 | 0 |
18 | Locked | 40.3 | 4 | 0 |
19 | Locked | 38.9 | 5 | 0 |
20 | Locked | 40.3 | 0 | 0 |
21 | Locked | 40.3 | 4 | 0 |
22 | Locked | 40.3 | 6 | 0 |
23 | Locked | 38.9 | 5 | 0 |
24 | Locked | 38.9 | 0 | 0 |
on 24-09-2021 16:34
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 53700000 | 47.8 | 5120 | 64 qam | 6 |
2 | 60300000 | 48.3 | 5120 | 64 qam | 5 |
3 | 46200000 | 46.8 | 5120 | 64 qam | 7 |
4 | 39400000 | 46.3 | 5120 | 64 qam | 8 |
Upstream bonded channels (2)
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
General Configuration
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt062-b.cm |
SFID | 59040 |
Max Traffic Rate | 402500089 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 59039 |
Max Traffic Rate | 38500089 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
on 24-09-2021 16:34
24-09-2021 16:59 - edited 24-09-2021 17:01
Stats all look fine - logs dont though - the dreaded ATOM error (not sure what that is!) that crops up with some users from time to time.
Do you see the disconnections on ethernet cable connections at the same time as on wifi ones - if you arent sure - can you test it
Whilst waiting for more input can you do this....
____________________________________________________
If you haven’t already, set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph” (as per instructions on the TB website) when it starts to develop.
on 24-09-2021 17:13
on 24-09-2021 19:32
on 24-09-2021 19:53
on 24-09-2021 19:55
on 24-09-2021 19:56
Thank you.
