  • 6
stevgil
Message 1 of 11
Switching to Modem Mode on Hub 3 Router
I'm receiving high EMF readings from my router even though I've turned wifi off in the router. As I'm not bothered about using wi-fi, will switching to modem mode help reduce this?
  • 11.36K
  • 404
  • 1000
Message 2 of 11
Re: Switching to Modem Mode on Hub 3 Router
It likely the Docsis modem that causing this.
  • 4.77K
  • 371
  • 788
Superstar
Message 3 of 11
If you are using your own router and are worried about the EMF the only answer is to put the VM hub in an earthed steel box. Might get a bit hot thought.
There are 10 types of people: those who understand binary and those who don't and F people out of 10 who do not understand hexadecimal
  • 6
stevgil
Message 4 of 11
@Thanks for that @legacy1. Yes, I'd guess that it must be related to Docsis so I'm not sure how to proceed. Perhaps I'll need to go back to a lower bandwidth solution through the telephone, though I'd rather stick with cable if possible. I'm going to try shielding the router with some appropriate material. I know most people want blazing speeds so I must be in the minority to want to cool it down. I came across a JRS Eco Wifi router but perhaps in my current setup that wouldn't be an option. Again, thanks for pointing to Docsis as I really hadn't heard about it.
  • 6
stevgil
Message 5 of 11
@Thanks @Tudor as I'm going to try this. There are either material or metal options available so I might try the material one first.
  • 11.36K
  • 404
  • 1000
Message 6 of 11
Give your hub a nice tinfoil hat for Christmas complete with body warmerSmiley Tongue
  • 24.59K
  • 1.02K
  • 3.83K
Message 7 of 11
Like this one Smiley Wink
tin-baseball
  • 253
  • 25
  • 70
DreamOfCheese
Superfast
Message 8 of 11
Is it really worth the effort of going out of your way to block EM emissions from the Hub when chances are your neighbours also have wireless networks, and even if they don't there are a plethora of signals transmitted on various bands, AM/FM radio, GPS, 2G/3G/4G networks, etc.
The non-ionizing radiation at regulated power levels isn't going to do any harm to any organism, unless that's not your concern and it's actually to do with interference with other appliances.
  • 6
stevgil
Message 9 of 11
Thanks for replying. I've put my router in a Shredded Wheat box and covered it with aluminium foil which has reduced the RF a couple of notches on my EMF meter. I'm feeling better already! I know what you mean about neighbours' networks etc., but I only wanted to reduce the overall 'radiation' which is well-known to harm organisms long-term from what I've discovered - it's just that those who really know this aren't telling us about it!
  • 24.59K
  • 1.02K
  • 3.83K
Message 10 of 11
i recommend to turn off everythong you own and leave it off.
