  • 7
Denrog
Message 11 of 17
Re: Switch not working after hub 3 pin reset
Hi, thanks, why would this happen after a reset? It was ok before. If this is the issue can you suggest a remedy?
  • 12.54K
  • 480
  • 1.12K
Message 12 of 17
Maybe your hub got updated.
You can try one device at a time to the switch instead of all devices connected.
  • 7
Denrog
Message 13 of 17
I turned ''smart" option off on the router. Then plugged cables in to switch one by one and found that all was fine until the dvd cable went in. It won't accept the dvd cable even if that's the only device. Really odd?? But it all seems to work now (excluding dvd, but we don't use internet services on the dvd player anyway).
Thank you to all who gave advice. Much appreciated.
  • 12.54K
  • 480
  • 1.12K
Message 14 of 17
Likely the dvd does some what the hub thinks is odd DHCP.
  • 7
Denrog
Message 15 of 17
More out of curiosity than necessity, is there a fix for that?
  • 12.54K
  • 480
  • 1.12K
Message 16 of 17
What happens if you connect the DVD directly to the hub?
You could try setting a static IP on the DVD.
  • 7
Denrog
Message 17 of 17
Not really possible as they're very far apart. The switch is 30 meters away from the hub in a summerhouse at bottom of garden and the dvd player is in there. I could bring dvd player in to house and test it but I'd also need to set a TV up near the hub. If I get a chance to do this I'll let you know.
