  • 42
  • 8
  • 8
Dialled in
Message 11 of 16
Re: Superhub3 issues for many if pfSense firewalls used
From memory, You go to the upgade section in Pfsense and choose from the drop down menu which version you are seeking to upgrade to.It will have the DEV train of software there.
If you have a "production" enviornment it is highly recommended not to use anthing other that the latest supported version and stay away from Alpha or Beta or Dev - Developement versions.
Dev versions inflict pain on you and all the users of the network due to its Developement status.
KK
  • 13.96K
  • 574
  • 1.33K
Message 12 of 16
@g0nz0 wrote:.
How did you upgrade to 2.5.x Dev?
https://www.pfsense.org/snapshots/
BQM, Test for outgoing ports and SSL/L2TP VPN test
  • 6
Message 13 of 16
To upgrade to DEV version, click on system > update > update settings > branch > select "latest development snapshots" > save.
Go back to system > update > then an update option will appear to upgrade to 2.5.x.
  • 21
Message 14 of 16
bennnnm07 - could you let us know if it is still stable (been 4 days since you posted) using pfsense version 2.5.x?
  • 6
Message 15 of 16
Fezster,
Broadband has been perfect, had zero issues since the upgrade to 2.5.x.
Ben
  • 21
Message 16 of 16
Thanks - I have a 2.5 pfsense VM setup ready to use.
But before doing so, I tried the following.
I've made 2 changes:
Disable Gateway Monitoring Action
Disable "Block bogon networks" on WAN interface
Seems to be positive so far - but it's early days.
This bug report may be relevant: https://redmine.pfsense.org/issues/10414
Thread discussing this issue in more detail here: https://forum.kitz.co.uk/index.php/topic,24600.45.html
