  • 2.18K
  • 320
  • 562
av-115
Problem sorter
Message 51 of 56
Re: Superhub spontaneously resets to default settings INCLUDING DEFAULT PASSWORD
@Joe_F wrote:
I see, are you able to connect that into a socket in the wall, this could be causing a power issue.
 Thanks Joe_F
How can this be a power issue? It either has power or it doesn't. If it loses power, it reboots, not resets. Just send him another Hub 3 to try. I've had the Hub 3 for nearly 3 years, one of the original white ones, it's in router mode and plugged in at an extension lead. It's crap, but I've never had this reset issue.
TV: XL TV + Sky Sports (V6 & V+ HD)
Broadband: VIVID 200
Phone: Talk Unlimited
  • 9
galthop
Message 52 of 56
Looks like it is related to power. I unplugged it for a few minutes and after it had lost the WiFi settings, router password, port forwarding and port filtering but the DHCP reservations were not lost. The last two times everything was lost.
@Joe_F wrote:
Cheers, keep us posted if this issue arises again, we may need to look into this in more depth.
Thanks Joe_F
  • 37
procurator
Message 53 of 56
Just tried changing my wifi password & network name to a more secure one. Saved the new settings. All fine and my wifi devices connected to the new configuration with the new password. Switched the superhub off and on again and all my secure configuration settings have all gone and the the superhub settings are back to the factory network name and password. I did not perform a factory reset, just switched it off as one does when not needing it wasting electricity. Surely this is a faulty superhub if it can be compromised by simply turning the power on/off. If so please arrange for a replacement superhub to be sent out.
Kind regards
Kenny
  • 7
PeterCass1
Message 54 of 56
I'm having the exact same issue for a while now..  A simple reboot and the Hub 3.0 is back to factory settings. Very annoying..
Standard specification compliant: DOCSIS 3.0
Hardware version: 10
Software version: 9.1.1802.610
Any help would be much appreciated
  • 72
  • 6
Message 55 of 56
Hi, PeterCass1.
Thanks for reaching out. Sorry you're having this issue.
Is your Hub's PSU plugged into an extension socket? If so please connect directly to a wall-mounted socket and monitor.
If it is and it's still happening, we can look into this further and we should be able to provide a replacement to see if this resolves the issue. We can do this via online chat.
Let us know how it goes.
Rule_C
  • 37
procurator
Message 56 of 56
I've now experienced 2 months of waiting for a response to this issue. Does no one at VM want to take the opportunity to make this right?
Kenny
Kind regards
Kenny
