  • 852
  • 30
  • 65
Message 41 of 56
Re: Superhub spontaneously resets to default settings INCLUDING DEFAULT PASSWORD
Thanks, Your hub is it plugged into an extension or straight into the wall galthop?
Thanks Joe_F
  • 9
galthop
Message 42 of 56
It is connected directly to the box on the wall where the virgin cable comes in to the house.
  • 852
  • 30
  • 65
Message 43 of 56
I see, are you able to try this is another socker / plug? Just so we can rule out a power issue Smiley Happy
Thanks Joe_F
  • 11.9K
  • 437
  • 1.05K
Message 44 of 56
Try the hub in modem mode it likely will not reset to defaults then go get a wireless router with 1Gb ports.
  • 9
galthop
Message 45 of 56
I don't want to buy a separate router when I already pay virgin for one.
  • 9
galthop
Message 46 of 56
I thought you meant the cable wire. The hub power is connected to an extender but so are other things which are fine.
Also, why would losing power reset the settings? It does not normally if I switch the power off and other devices don't lose their settings if power goes off.
  • 852
  • 30
  • 65
Message 47 of 56
I see, are you able to connect that into a socket in the wall, this could be causing a power issue.
Thanks Joe_F
  • 9
galthop
Message 48 of 56
I'll connect it directly to the wall and see what happens.
Thanks Joe_F
  • 852
  • 30
  • 65
Message 49 of 56
Cheers, keep us posted if this issue arises again, we may need to look into this in more depth.
Thanks Joe_F
  • 11.9K
  • 437
  • 1.05K
Message 50 of 56
It could well be a vulnerability in router mode that given packets can make it reset.
